#21 |
so should i just throw the parts in from the rs150mtm, stuff it and seal it? then add/ remove stuffing by ear?
#22 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I was just offering a dirty solution for Mark, but after seeing the response graph for his woofer....yeah it does break up bad & the two in combo will really be all over the map.
Yes you are right , I see...the resolution is not precise enough to fix this "problem". Best to fix it on the Xover end.....as in get it right rather than putting a band-aid on it. Using a 12 band can be used for mild compensations, but this combo just won't work right & I do believe you all have nailed down a better choice for his first build. _____________________________________Rick......... ... |
| Sanity check - mad about sound lm3886 stereo amp build | KieranC | Chip Amps | 35 | 2nd January 2009 03:30 PM |
| pentode driver sanity check - before i build | zobsky | Tubes / Valves | 5 | 5th July 2006 02:55 PM |
| Sanity check - designing my speaker to be 8ohm amplifier friendly. | owdi | Multi-Way | 4 | 1st November 2005 10:08 PM |
| speaker phase check | sma | Swap Meet | 0 | 12th February 2005 07:45 AM |
| P17WJ speaker box check | Tensop | Multi-Way | 16 | 10th January 2004 12:08 PM |
