Transmission Line Question - Page 2 - diyAudio
Old 17th September 2007, 12:08 AM   #11
lovitz is offline lovitz  Canada
What are your plans for Crossovers and amplification?
Old 27th February 2008, 03:59 PM   #12
hello,i was trying to find out how the results of this project went,since i am working on a simular one......also i would like to get in contact with Bjorno,if i may.
thanks John
thanks John
Old 27th February 2008, 07:44 PM   #13
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
...since i am working on a simular one......also i would like to get in contact with Bjorno,if i may.
Hi John,
Tell us about your current project!
b
Old 27th February 2008, 11:34 PM   #14
hi b,thanks for your response,i have a Volt 3143,atc 75/150 non s ,and SS 9700..
cab. is 36 7/8"h,25 7/8"d,15"w.....the front line wall is 9" at the bottom and 8" at top and 21 1/2"h(inside dimension)all 1"mdf.
the rear line wall is 7 1/2"from back and bottom and is straight .
the top exit line is 5"at vent(although the vent was cut 4x12") and the rear vent is 6" and 17 1/2 long..........all inside dimensions. confusing i'm sure but i cant put my pics on only e-mail them,the post won't allow it......i would appreciate any help...my prototype sounds not bad so far but my bottom seems wobbly.
thanks john
thanks John
Old 28th February 2008, 02:16 PM   #15
John,
Your description didnít add up when I tried to make a drawing. You could instead give an instruction, a list of all the cross section areas (CSA: s) and section lengths starting from the closed side of the TL all the way to the open end and point out where the driver is located.
Use MJK: s example as a template: See picture 1(1)
b
1(1)
Old 28th February 2008, 04:22 PM   #16
hi b,yes i see now what u mean,it is a 3 chamber with the exit out top front like the PMC MB2, so the 1rst csa is:
9" then behind woofer is 4"(although when i add another 1"front piece for a 2" front will change it to 4 1/2").driver locat is 8 1/2"
next csa is 8" then our first turn 11 1/4, 8, 10 1/4,7 1/2
bottom middle inside turn 6 3/4, 9 1/4, 6 3/4 , 9 1/4, 6 1/2
top turn,6 1/2, 8 7/8 ,6 1/4 and exit is 5"
line lenths are(from closed to open)
24", 8 1/2", 24", 7 1/2", 28", 21 1/2"
csa-9,DL-8 1/2,8,11 1/4,8,10 1/4,7 1/2,6 3/4,9 1/4,6 1/2,6 1/2,
8 7/8,6 1/4,5
i hope this will help B,my anniversary today so gotta go ,thank you very much,
John
thanks John
Old 29th February 2008, 02:34 PM   #17
hi B,i was shopping with my wife yesterday and bought some memory foam at 3" thick,it is about the perfect thickness for behind woofer. Have you ever tried this product?$$$$$
i am currently using some grey(like roadcase material) 1.5" eggcrate material i purchased from Solen,but was always curious about memory foam..
i just hooked up a Bryston 10b LR x-over at 380 and 3800hz.. the bass is much tighter than the Ashley XR-2001,although the mid is way to high,maybe 2-way,3-way switch is stuck,i will work on this more...
look foreward to hearing back
John
thanks John
Old 29th February 2008, 11:38 PM   #18
John
Memory foam is mostly a closed-cell foam, which means that while it absorbs physical impact, it wil be a poor sound absorber overall. You will, at the least, alter the effective enclosure volume.
-- Mark
Old 1st March 2008, 12:40 AM   #19
thank you Mark,
it will be put behind the woofer only for tuning,not throughout ...
have you tried this product??
john
thanks John
Old 4th March 2008, 07:45 AM   #20
hi B, i was wondering if the numbers i gave made more sense,look forward to your response.
john
thanks John
Transmission Line Question (Yet Another) schmeet Subwoofers 24 6th August 2008 10:18 PM
yet another transmission line question CharlieM Multi-Way 3 6th July 2008 05:44 PM
another transmission line question CharlieM Multi-Way 8 21st March 2008 11:17 PM
Transmission line question(s) Kris0603 Multi-Way 20 28th September 2005 11:15 AM
Transmission line subwoofer question Street Subwoofers 16 14th August 2003 03:33 AM
Copyright ©1999-2017 diyAudio
