Hi to all,
I have a question regarding type of caps which I can use for upgradinfg of my Kef Reference model two speakers. I looked at the crossover and saw only BI- Polar and NON-Polar capacitors has been used. Could somebody tell me please what is the difference between them( Bi-Polar and NON-Polar caps) and could I use let say Mundorf Supreme caps. instead ( but nothing said what kind of type they are.), or I have to replace Bi-polar with Bi-Polar and NON-Polar with NON-Polar ones. Tanks. Vadimgal |
#2 |
Bi polar is what they say on caps that look (constructively) the same as electrolytic caps, just to make sure if you have a collection of both types you don't mix them up. (because they have a completely different function)
Basically they do the same thing as non polar types. Basically parallel placed caps (parallel to the driver...) can better be the cheaper bi polar ones, low loss results in higher loss (for as far as I know) when placed in parallel with the driver/signal... Series placed caps better be good low loss quality and high voltage rating non polar foil caps. Quality starts at mylar (MKT) than MKC (don't know what plastic they use in there from my head...) than MKP (which is way better than what most commercial designs have already... Than there are exotic ones.... PS bipolar can be raw or smooth foil, never use raw ones as they are generally too poor quality for any application in speaker filters....
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#3 |
Bipolar and non-polar mean the same thing, and all capacitors sold as speaker crossover capacitors will be non-polarized. Polar electrolytic or tantalum capacitors must be hooked up with one terminal positive and the other negative, and are really only used for things like power supply filtering and not for audio crossovers.
As for different types, bipolar electrolytics are a starting point, with metallized film such as metallized mylar/polyester being next, and meta film and foil capacitors being significantly larger and more expensive, but arguably better suited for crossovers. In practice, the differences are difficult if not impossible to discern, especially between film and foil or metallized film capacitors. All foil in electrolytic capacitors is etched, and isn't "smooth", to increase the surface area of the electrode and the capacitance of the capacitor. Also, it doesn't matter a great deal whether the capacitor is in parallel or serial, as both are "in the signal path" and affect the audio signal, otherwise you'd just leave out any parallel capacitor. Good luck, John |
#4 | |||
| what capacitor type is best used on Carlosfm's non-inverting chipamp? | jarthel | Chip Amps | 8 | 24th August 2007 12:12 AM |
| Capacitor type for crossover | ThSpeakerDude88 | Multi-Way | 23 | 4th August 2007 09:00 AM |
| Capacitor Type ... Help | papanohn | Parts | 8 | 13th November 2006 08:34 PM |
| Capacitor type for simple headphone amp | GianLorenzo | Headphone Systems | 3 | 20th December 2004 08:45 AM |
| what type of capacitor to protect tweeter in active filter setup | timsch75 | Multi-Way | 8 | 9th December 2004 10:53 PM |
| Page generated in 0.09922 seconds (72.16% PHP - 27.84% MySQL) with 10 queries |
