I was scanning Ebay and found these Mini 7s with what looks like a different Woofer than usual.
is this some cheaper variant? |
#2 |
I'm not sure from the photo because the grill is in place, but they look very much like mine (1977-78). The woofer cone wasn't black, but rather a lighter tone paper.
Remember that over the lenghty period of time that they were being sold that there were different configurations (example: sealed *and* ported) plus several different sources for the woofers and perhaps the tweeters as well. Radio Shack was terrible about changing components, as well as drivers, and never documenting or designating the changes. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#3 | |
(((FYI, The reason I bought a dozen of these nice and good performing 4" bass drivers back in 1985 were to do experiment with bookshelf de-correlated bass arrays, a 2. (1+2) system. I’m still using them corner placed in two rows, together with a TL sub (XO at 50 Hz/ 12 dB octave) placed centrally in the same bookshelf that covers entirely one of the short walls. See the skeleton of the TL bookshelf sub I built –91 used with various sub drivers, latest and best performer a Peerless 10” 830842 bought when the driver was preliminary new and factory released. Using L+R or L-R signals variable delayed (typically 5-40 mS depending on the recorded definition) and mixed, weighted with ordinary L+R or L-R to counter weight any destructive bass interference at the listening point from the main sub is defeated or lowered as the arrays form a 1(L array) + 2(sub) + or -1(R array) weighted straight or bessel array for signals below about 78 Hz (array c-c= 2.2m = lambda/2). The arrays are filtered with a 3 dB slope from 50 Hz i.e. 100 to about 800 Hz at a level suitable for the definition of the recorded material, -6 dB or lower and really, in my opinion makes a real difference for most of my vinyl or cd recordings. When comparing the soundstage with the preceding set-up the 2.1 system only i.e. the bookshelf-sub and bookshelf mains L + R with the 2. (1+2) system none of my friends prefer the former set-up and I agree too, especially when playing concerts, chorals or old Jazz stereo or mono recordings.))) b 1(4) |
#4 |
2(4)
#5 |
3(4)
#6 |
4(4)
#7 | |
Magneto the Gravity Man
These also look identical to the pair I have. They are also very similar to a pair made by Aiwa purchased in 1977 in Singapore - same case and drive units Andy |
#8 |
To me it looks like the dust cap is smaller and the surround is thicker and juts forward more than my Mini 7. Most of the Mini 7's I've seen use the Woofer Bjorno has. ( didn't know they sold the woofer separate, my RS DIY 4 inch Woofers are noticeably different from the Mini 7 Woofer).
#9 |
Bjorno,
You wouldn't happen to have info on Radio Shack's vintage woofer model "40-8424" wouldn't you? Ive been looking for it... |
#10 | ||
Here is a link to a guy who has some experience with this driver: http://homepage.mac.com/dero72/speakers/subwoofers.html He wrote: Quote:
| WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) | gtforme00 | Swap Meet | 9 | 3rd June 2008 09:57 PM |
| the Very Mini Magico Mini | zei | Multi-Way | 7 | 11th February 2008 08:10 PM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
| Using DVC woofers as 2 seperate woofers | Hybrid fourdoor | Multi-Way | 2 | 15th June 2003 12:10 AM |
| Page generated in 0.11360 seconds (76.35% PHP - 23.65% MySQL) with 11 queries |
