I work with some W8LC boxes which consist of:
12" (300mm)/3" (75mm) voice coil, Hybrid™ bass horn loaded 2 x 6.5" (165mm)/1.5" (38mm) coil drivers, horn loaded 3 x 1" (25mm) exit HF compression drivers, horn loaded They are designed to be used with external active crossovers made by Lake. My question is this, on the back of the NL8 input panel is a network of capacitors and resistors which are connected to the HF Drivers. Being a novice, I initially assumed that it was a xover network, but these boxes are externally crossed over, and the cap/resistor network is only connected to the HF drivers. What is this network? What does it do? Does it have something to do with the HF's being compression drivers? Just curious. |
#2 |
I assume (as I'm not familiar with the design) it is there to protect the high frequency driver against DC/low freqs... And some attenuation?
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#3 |
Picture or (preferably) schematic of this network? It should be pretty easy to tell it's effect from the schematic.
#4 |
I quickly drew up a diagram in mspaint. I hope it's clear enough.
obviously, the large cap is 10 uF, the 2 small ones are 1 uF, and the resistor is 12 ohms. |
#5 |
Well, I'd have to know the impedance of the tweeter to tell you more, but that circuit creates a 1st order high pass network (6dB/oct, and the 10uF means it's probably at a fairly low frequency) and then reduces the lower end of the tweeter response (effectively "boosting" the upper end the response by comparison). I don't know at what point it begins the boost, but the 2uF (effective) cap would suggests it starts fairly low (4Khz? Lower?) and the 12ohm resistor provides a fairly significant cut. It probably does this because the tweeter response rolls off at higher frequencies.
#6 |
The datasheet says the HF drivers are 8 Ohms, but I assume that's all 3 drivers in parallel.
#7 |
Well, if the network applies to all three drivers then you would consider their combined impedance.
#8 |
May be someone have a drawing W8LC ???
Send me please cibercut@yandex.ru |
#9 |
Warmest regards, Ferrit37 |
| martin logan's | dsiroky | Pass Labs | 17 | 16th April 2007 10:13 AM |
| Martin J King's Ported Sheets-Vent Height Question | kelticwizard | Multi-Way | 7 | 25th April 2006 12:49 PM |
| Martin Audio WSX-Hornbass | teletoby | Multi-Way | 2 | 2nd March 2006 04:38 AM |
| martin logan csl | flodge | Planars & Exotics | 12 | 13th November 2005 02:59 PM |
| Martin Audio BX2 for sale | Bull | Swap Meet | 0 | 3rd June 2005 03:05 PM |
| Page generated in 0.09866 seconds (73.79% PHP - 26.21% MySQL) with 11 queries |
