Old 10th September 2007, 04:56 PM   #1
cypher is offline cypher  Poland
Default SS9700+Peerless HDS 205 EXCLUSIVE
Recently almost by coincident I became happy owner of Scan Speak 9700 tweeter..;-))
I would like to build monitors around 20L in close cabinet or reasonable small vented monitors with Peerless HDS 205 EXCLUSIVE (P830884).
I wonder if this set will work well together an will be ease to drive by parallel single ended amplifier based on EL34 tubes..(high efficiency is not a problem because I do not play music loud but transparency, stereo, sound stage and vocals this is my primary concern..
Any suggestions more than welcome ..;-))
Art
Old 11th September 2007, 12:44 AM   #2
The HDS 205 is very easy to work with and it has a very smooth response. It sounds very good indeed. I am sure it mates very well with the 9700. Given that the HDS 205 is only a 5 1/2" driver it does not go low so I guess I would use two of them in a MTM. More sensitivity is needed if driven by a tube amp.
Old 11th September 2007, 12:45 AM   #3
Also try a series XO on the HDS 205 and it can sound absolutely first class. I have 8 x HDS 205 drivers sitting around and someday I will follow your path and build some speakers dedicated to tube amps.
Old 11th September 2007, 02:23 AM   #4
5th element's Avatar
The 830844 Cypher originally speaks of is the 8" HDS Exclusive, not the 5" version.
However I don't think it matters too much as per say. Make sure you crossover at around 2000hz with steep filters and you'll be okay. As 8 inchers go this one has quite a well extended response, especially off axis, but this is skewed somwhat when you notice the on axis rises with frequency.
I currently use the same tweeter and think it sounds fantastic, should mate well, with how tubes are supposed to sound.
Measurements are a must though, as they always are.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 11th September 2007, 03:04 AM   #5
Oop! we have some confusions here.
The HDS 205 is 850490, not 830884, I suppose. This one is 8".
And 850488 is HDS 134. This one is 5".
I have 8 x 850490 and 8 x 850488 on hands and have lived with them for a couple of years. I tried a series XO on the 850488 and it sounded fabulous.
Yes, measurement is important to get them to work at their potentials.
I found the 850490 limited in low bass.
Morel CAW 938 vs. Peerless Exclusive 8'' for MDM 55 and OW I Project leifislive Multi-Way 17 3rd March 2009 06:07 AM
FS: 2 Peerless Exclusive 831882 5.75's kappa546 Swap Meet 0 10th January 2009 12:25 AM
Peerless HDS Exclusive - consistency check Multi-Way 6 17th July 2008 11:44 AM
Peerless Exclusive 831882 - 5.5 build Shim Multi-Way 0 6th October 2007 02:17 PM
ML-TQWT with Peerless HDS exclusive? tubee Multi-Way 0 18th June 2007 08:00 AM
Page generated in 0.09899 seconds (76.65% PHP - 23.35% MySQL) with 10 queries
