Everyone should be aware of the ARG 2 ribbon used in the GR Research Criterion. The story i have heard is that this is a further development from the same designer of the Ravens. It sounded good in the Criterion, and anecdotal comments are that it as least as good as the R1 -- and about $190 USD everyday.
dave
dave
Banned
Joined 2002
Banned
Joined 2002
BrianGT said:The Raven R1 is the deal of day at parts express for $189
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=276-300
It sounds like a fun project with the Jordan JX150 drivers. Has anyone combined these with the Raven tweeter? I like the JX92S that I have, but it doesn't go low enough. The JX150 seems to go low enough.
Parts Express says:
"Hurry, This Deal Expires 02/17/03 At 6:00 PM! "
Brian
AHEMM!!!
AHEMMM!!!
Banned
Joined 2002
JasonL said:YES!!! common man Help im in need of speakers i have no speakers to hook up to my new aleph's
You keep flopping around between a line array and a more convential speaker... you need to decide.
Why don't you order up 4 TB W3-871s from Bob and see how you like them (i have a box design for these -- Rick Shultz also has a design -- that does the next step beyond the ELF)
Then if you like tehm you can tackle an array. Otherwise you can head towards a more convential system with fewer, more expensive & generally better drivers.
In either case you'll have a decent set of little sats for back-up use.
dave
Banned
Joined 2002
- scan-speak reference-plus opinions
