Closed End Transmission Line
Old 18th November 2010, 06:49 PM   #31
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Originally Posted by planet10 View Post
The B&W would have been 4-way with or without the TL.
dave
True, the design wouldnt have looked right otherwise. I'm a bit gutted if I can't use a single closed TL between 175 hz - 20khz .. thought that was the answer to my prayers.
Old 5th August 2017, 11:43 PM   #32
slmnklyc is offline slmnklyc  Turkey
Lightbulb Tapering shape and volume and lenght???
1/2 wave is 1-way. And it changes if the line is tapered. This Natilus prototype can be shorter because of the taper.
dave
Hi.
(1.25-2)Sd suggested beginning cross sectional area.
Length is 340/2f meters.
While tapering The tube, Is there any restrictions about VOLUME?
Supravox 165lb:
Sd:165cm2
Fs:64hz
Vas:42L.
When I calculated The straight closed end pipe Volume is about 46L.
It is some kind of infinite baffle.
340m/s is The speed of Sound.I think stuffing also affect this Value.
How do tapering effect The lenght?
Is there any equation to calculate The lenght when tapering being used?
(Lets say simple tapered shapes used to calculate easily).
Lets say we use use tapering wrt fibonacci serie.
Old 6th August 2017, 12:20 AM   #33
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
You should try to preserve volume
How do tapering effect The length?
If the line tapers towards a point, the line can be shorter. It is an attempt at an IB but smaller with the intent of the long, well-stuffed line to absorb the entire backwave.
Does not significantly effect the speed of sound.
There are simulators, they are usually used for ľ wave lines, donít know how they handle Ĺ wave lines.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th August 2017, 12:40 AM   #34
dave
Sorry But I couldn't understand.
If I should preserve Volume while tapering,I should start with bigger starting cross sectional area to obtain same Volume?
I started to think Volume(closed) is only related to ordinary closed box(air suspension or infinite).
And lenght should be FIX is 340/2f meter?
If use symetrical shape Volume, can I use The middle line For calculations?
Old 6th August 2017, 12:53 AM   #35
Lets say we reduce The Volume to acoustic suspension volume and leght is The SAME.
Is it still possible to eliminate the ALL backwaves like the big Volume we started?
Old 6th August 2017, 12:54 AM   #36
phivates is offline phivates  United States
The thing is, a well damped 1/4 wave open TL actually works very well. The experts can advise on taper. If you like complexity, make a BLH.
Old 6th August 2017, 01:15 AM   #37
I also like The Mr.Tetsuo Nagaoka 'Hasehiro back loaded horns' Design.
But I am still chasing my questions.My brain isn't there
Old 6th August 2017, 03:30 AM   #38
frugal-phile(tm)
planet10's Avatar
Yes. The line can be shortened because th etaper bunches up the harmonics.
Bass response will be much the same as the driver in the available volume.
And length should be FIXs 340/2f meter?
You can, but it really should shorten a bit from that. How much depends on the amount of taper.
dave
Old 6th August 2017, 04:16 AM   #39
So can we assume Volume will be enough to break The air spring and The lenght will be 340/2f meter(tapering shorten this lenght).
It is pretty big enclosure For full range and woofer Drivers.
If I crossover The woofer at 200hz I can use full range Driver in The closed TL with managable size..
Can I ask a question out of this subject?
There are golden ratio enclosures in your site.
How do you classify them?(some kind of ported maybe?)
Thanks!!
Old 6th August 2017, 04:25 AM   #40
GM is offline GM  United States
GM's Avatar
Net volume [Vb] determines how much output it will have and its length the tuning, so reduce Vb reduces available [mid] bass output and in general a TL's Vb needs to be anywhere from 4-10x Vas to get good bass output, so if you start at a closed point and need a 100" line, then the driver baffle area at the open end will be whatever is necessary to get the desired Vb.
IOW, if you make a TL's Vb = required for AS, then better overall to just make an AS box.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Closed End Transmission LineHide this!Advertise here!
how to combine Line array and transmission line together Jared Multi-Way 7 15th December 2012 02:20 PM
closed end high frequency transmission lines thadman Multi-Way 6 8th April 2009 02:59 AM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 05:18 PM
Transmission Line for or against? DJ Sense Full Range 5 10th June 2006 09:35 AM
Copyright ©1999-2017 diyAudio
