Old 9th September 2007, 07:28 PM   #1
akunec is offline akunec  Canada
Default My new Speakers: PHL 1120, Morel Supreme, Lambda 12" w/ faraday
Hey guys,
I built some speakers using a PHL 1120, Morel Supreme, Lambda 12" w the single faraday ring. I tested them using ground plane measurements at 2m in a gym.
I designed the active crossover using LSPCad and theoretically should get plus or minus 1.1db from 55hz to 20khz.
I built the crossover with a delta audio active 1 circuit board and it tested nearly identical to the theoretical transfer function. + or - .1 or .2db.
Anyways, the sound is amazing. However sometimes the bass seems a little too overpowering. This is especially true for movies where the bass in someones voice makes it difficult to understand what they are saying.
So I was going to either seal the box, or put on a switchable filter to tame the bass a little. What do most ppl use for this problem?
Old 9th September 2007, 07:48 PM   #2
wigginjs's Avatar
Umm... pictures please
The Four Chairs
DIY Home Theater
Lambda Acoustics SBP10 (Faraday Ring) Zedguy Swap Meet 5 30th October 2007 09:47 PM
Morel Supreme 110 x MDT-33 wmj Multi-Way 5 17th November 2006 01:06 PM
Revelators vs Morel Supreme 110 6BX7GT Multi-Way 0 28th March 2006 03:59 AM
For Sale: Lambda Acoustics TD-15H (Faraday) Zedguy Swap Meet 6 6th February 2006 12:46 AM
FS: Lambda Acoustics TD12S (faraday) woofers pkpickard Swap Meet 5 18th December 2004 10:56 PM
Page generated in 0.08020 seconds (65.23% PHP - 34.77% MySQL) with 10 queries
