Old 9th September 2007, 03:17 PM   #1
mace is offline mace  United States
mace's Avatar
Default Inductor DCR ?
Hello all,
I am planning to start a new project soon,and am in the process of working up a BOM.
My question concerns the values of DCR with the required inductors, listed for the design.
Will the difference in DCR effect the outcome of the design?
The listed values are,
L1-2.5mH--.65Ohm
L2-.90mH--.36Ohm
L3-.30mH--.16Ohm
L4-1.25mH--.26Ohm
I would like to use Solen 16g. Perfect lay
Here are the values with DCR
L1-2.5mH--.59Ohm
L2-.90mH--.30Ohm
L3-.30mH--.16Ohm
L4-1.25mH--.25Ohm 14g
Thank you
Old 9th September 2007, 03:19 PM   #2
mace's Avatar
Also, would it be possible to go even lower with the DCR without adverse effects?
TIA
Old 9th September 2007, 04:33 PM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
A good general guide is the inductor should have a DCR that's less than 5% of the driver's Re.
To answer your question, no problems with those values.
Old 9th September 2007, 10:41 PM   #4
owdi is offline owdi  United States
owdi's Avatar
You might be able to save a bundle by buying from www.zalytron.com I never bought anything from them, yet, but their prices are awesome.
Choosing an inductor with a different RE will affect the design, but not by much. The values you quoted are so close that any differences will be swamped by variance within the inductor's tolerance limits. The only exception would be a high Q notch filter. These you want to measure to make sure you get right.
Dan
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Which inductor for PSU ? lordvader Parts 1 7th April 2008 03:21 AM
Inductor lot 875+ for the DIY RAW Multi-Way 1 14th August 2007 01:23 AM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 7th May 2007 11:02 PM
WTB: INductor:0.2, 0.25, 0.33& 0.9, CAP: 2.7uF&8.2uF gengis Swap Meet 0 6th July 2006 08:46 PM
Page generated in 0.07874 seconds (71.56% PHP - 28.44% MySQL) with 10 queries
