just a quick idea
what if we would use some sort of liquid filled area within an enclosure to help absord mechanical vibrations??? has it been done ? just thought of that trying to guess how i would be desiging my next OB loudpseaker for nearfield in wich baffle noises could be more of a problem i believe i thought about having some type of container with a liquid of a determined viscosity attached to the back of the baffle in an indentation ..probably glued to it another of my compeltly ridiculous ideas ? i believe so lets hear what you say now |
#2 |
I don't think this would work terribly well with anything with a lower viscosity than molasses. Molasses might work but if it was in a sealed space you might get fermentation then an explosion then an amazing mess to clear up.
Remember, sound travels more readily through a liquid like water than it does through air. Perhaps you need a vacuum rather than a liquid? Hard to implement though. Sand is probably a better bet. I made some spherical speakers that were essentially a sphere within a sphere. The space between the two was filled with sand. This has worked well. I think Gutta-percha fortified with fine lead granules would make a good sound deadening medium though I have never tried it. |
#3 |
hi cheapstake!
i was more thinking about mechanical movement of the baffle than sound itself i believe that all drivers induce some vibrations to the enclosure they are fastened to while moving nah ?? so i thought that a freely moving mass as a part of the enclosure/baffle would absorb some of the movement forces ... |
#4 |
Yes, the drivers certainly excite the enclosures.
Liquids don't necessarily 'absorb' the induced vibrations. Get a s/steel bowl, fill it with water and bang it. It will vibrate like a bell quite nicely. I think that to loose the energy in the vibration the material has to convert the energy into another form - heat? A mass of viscous liquid, I think, will just slosh and re-excite the baffle, converting only a small fraction of the energy into heat. You want something that converts mechanical vibration into heat readily or a great deal of mass that would require more energy to excite than ithe drivers can produce 8-) |
#5 | |
Superb answer!!! i will try to seak another path then .. thanks much! |
#6 |
Sand sounds like a far better bet than viscous liquid. |
#7 | |
#8 |
I think you'd get better damping with less volume using CSD (constrained layer damping).
----------------------------------------- Noah |
#9 |
| Infinite baffle vs Sealed enclosure | IG81 | Full Range | 2 | 4th March 2009 02:47 PM |
| Bandpass Enclosure & Baffle Step | 69stingray | Multi-Way | 2 | 12th July 2007 01:02 AM |
| open baffle enclosure for FRS | Jazzz | Full Range | 9 | 27th June 2007 02:41 PM |
| 166es-r enclosure and a baffle | kazoo | Full Range | 13 | 14th April 2007 07:25 PM |
| ideal baffle/enclosure shape for OB? | akunec | Multi-Way | 5 | 30th May 2005 01:14 AM |
| Page generated in 0.10106 seconds (77.34% PHP - 22.66% MySQL) with 10 queries |
