Round tractrix horn for my B&C DE250
Old 8th September 2007, 05:02 PM   #1
a007udio is offline a007udio  Romania
Default Round tractrix horn for my B&C DE250
I would like to make tractrix horn for my DE250. Can anyone help me?
I was trie to calculate horn with HornCalc but resaults are strange.
I will use DE250 from 1600Hz and up.
Old 8th September 2007, 08:08 PM   #2
GM is offline GM  United States
GM's Avatar
Default Re: Round tractrix horn for my B&C DE250
Greets!
Haven't tried simming a Tractrix in Hornresp, but for a 1600 Hz XO I'd want the horn to have a cut-off at least an octave below it, or ~800 Hz:
throat dia. = 1"
axial length = 3.75"
mouth dia. = ~5.4"
........and since it's a Tractrix, preferably ~ 1.5 octaves IMO, or ~565 Hz:
throat dia. = 1"
axial length = 6.625"
mouth dia. = ~7.65"
Regardless, you can't accurately input a compression driver's specs AFAIK since it is itself a 4th order band-pass speaker, so there's no way to accurately sim the driver/horn combination.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th September 2007, 08:32 PM   #3
Ok. Thanks.
I get similar results with HornCalc.
Would be anything wrong if i use horn with 350 hz cut-off.
Old 8th September 2007, 08:36 PM   #4
GM's Avatar
You're welcome!
Well, it will beam to a lower frequency and the center to center (ctc) spacing to the mid-bass will be larger, making the sonic blend even less coherent than the smaller, higher cut-off designs.
Old 8th September 2007, 08:44 PM   #5
So no easy way to do it.
And from where i could use my De250 with such (350hz) horn idealy?
Thanks for your help.
Old 8th September 2007, 10:46 PM   #6
GM's Avatar
You're welcome!
Good Q and without the driver's response in a plane wave tube (PWT) it's hard to say, at least for me since I have no experience with this driver. In theory the driver's compression (rear) chamber volume (Vb) will need to be increased to make best use of the horn's extra BW with the attendant reduction of acoustic efficiency since as is it's claimed to be designed for a 1600 Hz XO point, though for HIFI apps we can fudge this to a bit lower point and EQ it flat since we don't need a prosound's high SPL/protection requirements.
So lacking any other info, you can try it on a 350 Hz Tractrix with a > 990 Hz XO and EQ it ~flat in a HIFI app since the CC is tuned to a 1 kHz - up published BW and my SWAG is it will only handle ~30 W peak.
Old 11th September 2007, 01:22 PM   #7
I looks that i will buy a horn and not to made by my self.
Is there any good soruce of horns out there?
I was looking this one:
http://www.partsexpress.com/pe/showd...number=270-310
Any good?
Thanks.
Old 11th September 2007, 01:33 PM   #8
Brett is offline Brett
Brett's Avatar
Any good?
It's not a trax, and has a threaded insert, so you'll need an adaptor for a bolt on driver. I don't like adaptors.
Other sources
http://www.stereo-lab.de/
http://cgi.ebay.com.au/Neu-STATE-OF-...QQcmdZViewItem
www.ddshorn.com - ENG 1-90 Pro
Old 11th September 2007, 03:25 PM   #9
el`Ol is offline el`Ol  Germany
Here is the FR graph of a DE250 in a Supravox horn. Probably hard to beat.
http://www.supravox.fr/mesures/mespav1p1.htm
Old 12th September 2007, 06:40 AM   #10
I was looking links above. Nice horns, but prices are high.
Any cheaper alternative?
Any idea how low can i use my DE250?
Round tractrix horn for my B&C DE250Hide this!Advertise here!
Full size 142Hz round tractrix horns JLH Swap Meet 19 17th May 2010 12:16 AM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 03:12 AM
Tractrix horn AuroraB Multi-Way 12 8th September 2003 09:48 AM
Round Tractrix Horn System almost complete... Volvotreter Multi-Way 11 2nd August 2003 01:46 PM
