Hi guys.
Need some help. I have been working with the Focal tweeters for some time now and, without doubt, the overall performance is superior to most others. However, Focal, in their infinite wisdom, won't supply units anymore. Probably because other people get better results with their units than they do. Pathetic really, but there you go. This tweeter, with a bandpass filter set at 2500Hz and 22500Hz, sounds amazing and the response is ruler flat. I need a tweeter of similar quality that has a lift of 3-5 dB from 12-20KHz. Any ideas?? ( And don't say Audax, coz they're as bad as Focal). Ricky. |
#2 |
Hi Ricky,
I think you should still find some existing stock of these if you look hard enough, but you'll probably need to order from abroad. Zalytron and e-speakers should still have the TD5 version and ebay may well throw some up at times. 'Tis a shame about Focal and Audax.
I w isH i cuold typpe bettr |
#3 |
Hi.
Have you tried using the TC 90 TD5B, I know that it's not quite as nice but they are available in the states (Zalytron or E'speakers) from as little as £30 ($60) + taxes etc. I have used Zalytron for Focal drivers and the service was very good. Regards. Richard. |
#4 |
Hi.
Thanks for the info but the TD5 is no good to me. The reason it has to be the TDX is because the faceplate is removeable. So, I take the god-awful thing off and fit a nice 102mm diameter anodised round aluminium one. Focal have already told me to get knotted and I want to find in the region of 90-100 of these things. Thanks for all your help but I really think I'll hae to design using SEAS or a Scanspeak. Best Regards. Ricky. |
| drop-in REPLACEMENT for focal TC120Tdx2 tweeter | elves1111 | Multi-Way | 1 | 16th May 2008 05:07 AM |
| WTB: Focal Tc90tdx tweeter | Hewie | Swap Meet | 4 | 8th January 2008 05:18 PM |
| Replacement for Focal 7K415 drivers | spraglow | Multi-Way | 6 | 17th December 2006 04:43 PM |
| New NOS Focal tweeters TC90TDX | Josep | Swap Meet | 0 | 20th April 2006 11:28 PM |
| Opinions and use of Focal TC90tdx and 7K4411 | PaulHilgeman | Multi-Way | 4 | 2nd July 2003 05:48 PM |
| Page generated in 0.08890 seconds (68.26% PHP - 31.74% MySQL) with 10 queries |
