basic room accoustics..help design my ht room :)
Old 4th September 2007, 04:41 AM   #1
JinMTVT is offline JinMTVT  Canada
Default basic room accoustics..help design my ht room :)
As a few of you know,
i am in the process of building a new house,
wich will contain a few different audio systems.
One of wich is my HT room in the basement...
Now i need help for the room itself!
i have a 26' by 20' square space for it,
and i can do almost anything "crazy" i want with the walls
please keep in mind the following:
- surround system will consist of nearfield line arrays,
and an IB sub bass array of a few 18-21"
- house is build completly with ICF
( foam isolated concrete walls and ceiling on this room)
and i would like to do the walls with this material
- front screen width is of 100", so it require a minimum of front size for screen + mains + subs
here is a picture of a quick layout of what would be a possibility ...
i'd also like advices on possible reflection treatments ..
Old 4th September 2007, 05:19 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
26 x 0,618 = 16
16 x 0.618 = 9.9
Do you have room for 9' 10" ceilings
(9.618:1:1.618 is the AES recommended room dimension ratio....
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th September 2007, 05:23 AM   #3
9' ceiling for the front half
8' ceiling for the rear half
what about those AES measurements?
i don't quite understand the ratio you are quoting
i knew that you'd be the first to reply to this thread Dave
what do you think of the small angles i gaved to the walls in this quick sketch ?
Old 4th September 2007, 05:47 AM   #4
frugal-phile(tm)
planet10's Avatar
Originally posted by JinMTVT
[B]9' ceiling for the front half
average ceiling = 8,5 x 1.618 = 14.25
14.25 x 1.618 = 23
So your avaerage dimensions should be 23x14.5 x 23
That leaves a whole bunch of unised space --- use it for your woofers or...
almost as good
8,5 x 1.732 = 14.75
14.75 x 1.732 = 25.5
(still leaves ~850 ft^3 for woofers)
AES did a study to figure optimal ratio of LxWxH and ended up with a classic golden ratio box.
Angled bits are good.
dave
Old 4th September 2007, 12:35 PM   #5
R.I.P.
http://www.bbc.co.uk/rd/pubs/archive...icpractice.pdf
might give you some ideas, angled walls reduce flutter echo,
may not be needed depending on the acoustic treatment.
/sreten.
basic room accoustics..help design my ht room :)Hide this!Advertise here!
Nasty Room Resonances in New Listening Room TubeHead Johnny Multi-Way 4 24th May 2009 12:13 AM
Room design, DIY in-wall speakers, IB subwoofer, comments? wigginjs Multi-Way 10 3rd July 2008 09:12 PM
Room Accoustics and Soundproofing HiSix Everything Else 12 16th May 2007 07:37 PM
Big Room to Small Room CARTRulz Subwoofers 1 21st August 2006 06:59 AM
Cheap design for large room chrish Multi-Way 18 16th October 2005 10:41 AM
Copyright ©1999-2017 diyAudio
