Old 3rd September 2007, 08:56 PM   #1
Default Box wall thickness
How to know which wall thickness for your box that will most likely give you the best result?
After reading the much talked about BBC speaker building paper, I got the impression that out of two speakers, the one with the double thickness of the box walls gave the worst result. I would have guessed it would turn out the other way around. Aparently not. I have never come across this kind of information earlier.
Is it likely to affect all four walls, that is, side walls, back and baffel? My plan was to have the baffel and back double the thickness of the sligthly curved side panels.
Anyone willing to expand on the issue?
Old 4th September 2007, 12:04 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Thicknesses...
After building a dozen or so commisioned one-of-a-kind speaker enclosures, from slightly over 1.5 cubic feet on up to 24.5, I will use 5/8" for panels not to exceed 50 square inches, 3/4" for panels 144 square inches, anything over that I use one inch....MDF.
The larger ones of course weigh alot, for the one inch I use two inch woodscrews every five inches of panel.
My very subjective test of the workmanship of an enclosure is to rap it smartly with you knuckles, If it "sounds" solid as in a high frequency sound....like a large solid peice of wood.....ots' OK.
_____________________________________Rick......... .
Old 4th September 2007, 03:41 AM   #3
frugal-phile(tm)
planet10's Avatar
A lot of info here...
Discussion on what materials to build speakers out of
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
Lab Sub wall thickness question toshiba_nz Multi-Way 13 27th January 2008 01:53 AM
Sonotube Wall Thickness Dryseals Subwoofers 4 28th March 2006 05:15 AM
Opinions on wall to wall subwoofer array jmiyake Subwoofers 35 19th July 2003 11:26 PM
sonotube wall thickness mp3z24 Subwoofers 5 20th April 2002 06:39 AM
Page generated in 0.07524 seconds (69.77% PHP - 30.23% MySQL) with 10 queries
