I am messing around with line array using piezo's.I am a little slow on wiring.After reading posts and trying to understand as its easier in drawing form I came up with this.Am I even close?From the cts website I have the values but need help with putting it in layman's terms.I only need 1 per woofer but for asthetics I want 2,to get woofer line and tweeter line close in size.Thanks
#2 |
Speakerholic
Hi Shawn,
I have moved this to loudspeakers. Best I can tell, you have paralleled the tweeters with them out of phase. Also, the higher the frequency, the harder it is to integrate multiple units. See if you can get away with just one. |
#3 | |
#4 |
shawn I wonder if can you put up more precise details of the "cts website" you mentioned please? I'd be interested.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#5 |
#6 |
#7 |
Link won't work but the site is there if you type in.Its a whitepaper
#8 |
PE/Resources/Speaker Building
• Piezoelectric Tweeters (295K PDF) http://www.partsexpress.com/resources.cfm What kind of piezo do you have? |
#9 |
Yes thanks.Same paper.its the 1016 model which falls in the 3khz to 6khz category.
#10 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Piezo crossover | Pbassred | Multi-Way | 9 | 23rd November 2004 12:19 PM |
| Not piezo question again? | Zene Gillette | Multi-Way | 1 | 23rd November 2004 09:01 AM |
| Piezo compression | Pbassred | Multi-Way | 4 | 18th November 2004 06:01 PM |
| Using piezo tweeters | Rory | Multi-Way | 15 | 6th November 2001 08:46 PM |
| Page generated in 0.33757 seconds (-29.65% PHP - 129.65% MySQL) with 11 queries |
