Cal Weldon said:1 litre is 10cm^3.
No. Nono...
1 litre is 1000 cm³ or 1 dm³ or 0.001 m³. That is, a cube with the side 1 dm = 0.1 m = 10 cm encloses a volume of 1 litre.
Take the size in litres, multiply by 1000 and then take the cube root. That gives you the internal dimension in cm of a cube the right size.
If you take that number and multiply by 1.618 and divide it by 1.618 you get the dimensions in cm for a classic golden ratio box.
I will leave other shapes as an exercise
dave
dave
A cubic foot is a three dimensional area of space bounded by the dimensions of one foot by one foot by one foot.
.....soooooooo
A cubic litre has to be an area of space bounded by the dimensions of one litre by one litre by one litre.
Seems quite logical yet that doesn`t seem to work.
Coming into this from being comfortable in the antiquated Imperial system I found it impossible to wrap my mind around this, so I stick with building my cabinets in inches and foots. When volume is defined as cubic litres I have to de-convert into cubic foots. All this converting back and forth is a royal pain down around the cubic hairs.
.....soooooooo
I just read the question again and realized the answer is quite simple.
One and a half litres? That means they want you to make the cabinet out of a used beverage container.
damianl said:just say i have a driver needing a box volume of Eg. "1.53 Litr" how do i work out the dimensions. im new to this have only ever used kits.
sorry, but no areas of space...
Regions, yes, but an area refers to 2-D bounded surfaces. "Space" usually means 3-D. and is suitable as a volume. Every litre is approximately 60 cu. inches. or 1000 cubic centimetres.
take your volume in cubic centimetres and take the cube root of it. Times that value by:
[sqrt(5)+1]/2, and also by [sqrt(5)-1]/2
there's your dims, if a golden rectangle is desired for an enclosure (as Dave pointed out, the numbers are close to 1.62, and .62 respectively).
Those will be really tiny enclosures:
7.1cm X 11.5cm X 18.6cm
rcavictim said:cubic litre has to be an area of space bounded by the dimensions of one litre by one litre by one litre.
That is going to be an object in 9 dimensional space...
A liter is a volume unit, Like a gallon (=0.16 ft^3).
dave
http://www.kbapps.com/calculators/VolumeConversionCalculator.html
Imperial is also used in Europe along with Metric as are other measures like old "roman" (2.000 years old). I just don't know how much is a "football field"?!... is that mexican or english?
Imperial and/or metric are also used for screws.
Inductor said:I just don't know how much is a "football field"?!
In Canada a football field is 110 yds, in the US 100 yds. I understand that soccer & rugby pitcjes are variable in size.
dave
dave
Not being one to follow sports at all I was not aware of this blatant inconsistency in Canadian tolerance for lack of metric conversion. How is it allowed that a Canadian football field is not now 100 meters (or 110 metres) long?
We are still sold plywood in 4x8 foot dimensions but the thickness is now manufactured in millimeters. Goofy.
Here are two deep question for ya. How many dogs in a dog pound ? What is a dog pound in metric?
Just pondering the obscure while I sip my morning coffee and look out my window at my back meter.
rcavictim said:Here are two deep question for ya. How many dogs in a dog pound ? What is a dog pound in metric?
Dear me. Give some people an attoparsec and they'll take 16.09344 tera-angstroms.
rcavictim said:A cubic foot is a three dimensional area of space bounded by the dimensions of one foot by one foot by one foot.
.....soooooooo
I find it fascinating that one can have the same problem with the metric system as I have with feet and inches. And cubic feet. My feet are not cubical
BTW there is no such thing as a "cubic litre". Litre itself is a volume measure, equivalent to "cubic foot" or "gallon".
If you desperately want the word "cubic" in the unit then use it combined with the unit of length, eg "cubic metre" (=1000 litres) or "cubic decimetre" (=1 litre).
1 cubic foot = 3.048x3.048x3.048 = 28.3 litres
1 litre = 1/28.3 = 0.0353 cuft.
So a box of 56.6 litres is 56.6 * 0.0353 = 2.0 cuft
A box of 3 cuft = 3*28.3 litres= 84.9 litres
Svante said:No. Nono...
Svante,
I realize I wrote 10 cubic centimetres instead of 10 cm cubed. Big difference. Thank you.
planet10 said:In Canada a football field is 110 yds, in the US 100 yds.
In Canada a football field is 150 yds. In the US it is 120 yards.
You overlooked the end zones as part of the field.
sreten said:The obvious is to work in units of 10cm as 1litre = (10cm)^3.
(which is what CW meant I'm sure.....)
Yes, I forgot to add the parenthesis. Thanks sreten.
Cal Weldon said:In Canada a football field is 150 yds. In the US it is 120 yards.
I contemplated that... but the colloquilissm is to "run the length of the football field" which excludes the endzones.
dave
(1.53*1000)/chosen internal box height in cm. What you get you divide it again / chosen internal width. What is left is your internal depth in cm.
- litres to box size
