I think of building 3way floorstanding loudspeakers using HiVi units, I'm interested in bipole woofers design. Does the cabinet volume has to be doubled for 2 speakers in bipole design as it normally is in normal speakers placement or can it be smaller? Is it possible to mount them in cabinet with volume for only one unit (I prefer as small as possible)? The woofers are HiVi D10G |
#2 |
frugal-phile(tm)
The 2 woofers would require 2x the volume of a single to get the same alignment
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
If you use 4 drivers, 2+2 in an isobaric configuaration, the box volume will remain the same as it would be with only 1 woofer.
#4 |
According to standard calculations, yes, you'd need 2x the cabinet size. However, if you mount the bipole woofers magnet to magnet inside the cabinet, it's my experience that something strange happens, wave cancelation perhaps but that's only a guess, and you can get away with a cabinet 20%, or sometimes even 25% smaller, while still maintaining all the other calculations. The HiVi D10G woofer however is not a good candidate for that.
| Lowther bipole | britbug | Full Range | 16 | 6th May 2007 03:50 AM |
| t-amp with fostex 127e bipole or FR125 bipole? | alexg | Full Range | 6 | 23rd August 2006 07:49 AM |
| bipole configuration | summilux | Full Range | 1 | 28th February 2006 11:56 PM |
| Bipole efficiency | Jeb-D. | Full Range | 12 | 27th January 2006 06:55 AM |
| Bipole into Dipole? | Howard | Multi-Way | 1 | 30th January 2005 05:31 PM |
| Page generated in 0.08893 seconds (65.71% PHP - 34.29% MySQL) with 10 queries |
