Old 29th August 2007, 04:37 PM   #1
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Default What Driver Is Best From 800Hz & Lower?
If you were going to use the very "BEST" driver you know of to cover the frequency range of 800Hz and lower. What specific driver would you select ---(size, make & model # please)--- and what type enclosure would you use it in? Bass Reflex, Open Baffle, Infinite Baffle, Transmission line or horn?
I'm looking for speed, accuracy, tonal purity and bass extension. I don't care if it's a 15", 12", 10", 8" or 6" woofer!
Thanks, Thetubeguy1954
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
Old 29th August 2007, 05:03 PM   #2
Would you also use a subwoofer or this driver should cover all the bass?
Old 29th August 2007, 05:06 PM   #3
Robh3606's Avatar
Hello Tubeguy
How low on the bass extension?? You talking 20Hz or something more reasonable??? I have used a couple or JBL 15's that are capable of very good performance. The best all purpose would be a 2235 which has a good overall balance and can work up to 800Hz. You could also go with a 2234 which is the same driver less the mass ring so it's more efficient but sacrafices some bass response. If clarity,definition and speed is more important to you the E-145 is a very good woofer but is limited in it's range below 80Hz. To get useful output below 40Hz you would need a sub. These are all realtively efficient coming in at 93,96 and 98 db. The 2234/5 would want about 5 cubic ft where the E-145 would be happy in 4 cubic ft. You could drop all three into larger boxes for more low end if desired. These would all be bass reflex enclosures. They are all still suported by JBL so you could just purchase frames as cores and have fresh cone kits installed. That's what I did and it worked out to be cost effective. I had essentially "new" drivers when all was said and done.
Rob
Old 29th August 2007, 05:40 PM   #4
el`Ol is offline el`Ol  Germany
The Supravox 400 EXC would work up to 800Hz, as you can see at the off-axis response graphs, And I would use it IB if possible.
http://www.supravox.fr/haut_parleurs/400_2000_EXC.htm
Old 29th August 2007, 05:52 PM   #5
Default Driver
To provide more info... I'll be using 4 large HEIL drivers (per side) stacked in a quasi-source from 800Hz and up! Hence the need for speed, transparency and accuracy!
I'd like as much extension as possible on the low end without sacrificing speed, transparency and accuracy. If I absolutely must I'll use a sub. I believe the Heils are either 96dB or 93dB efficient.
Hope this additional info helps...
Thetubeguy1954
Old 29th August 2007, 09:06 PM   #6
Jay_WJ is offline Jay_WJ  United States
Any subwoofer or large size woofer will suffer to generate clean mids. If I were you, I would give priority to mids rather than to bass. I'd consider this (possibly two):
http://www.partsexpress.com/pe/showd...number=296-618
In a vented box, this will give more than enough bass for music listening. If your goal is to reach THX reference level without additional subwoofer(s), you'll need some compromise.
Old 29th August 2007, 09:27 PM   #7
dshortt9's Avatar
What overall efficiency are you aiming for? The Heils are more like 102 db from my experience. 4 stacked in what configuration? series, Parallel, or series parallel? The Heils are very fast and you want a woofer that is not slow. My speakers use 10" drivers salvaged from Klipsch RF-7's and are fast, transparent, dynamic. A good match to the Heil's.
Old 29th August 2007, 09:38 PM   #8
Default More Info
Hey dshortt9,
I'll be wiring the HEILS are a parallel-series to get an approx. nom 8ohm reading.
You're absolutely correct a need a driver from 800Hz and below that's extremely fast, accurate and transparent to match with the HEILS!
Thetubeguy1954
Old 29th August 2007, 11:30 PM   #9
For most applications, I'd say pro drivers crossed to a multi-driver sub.
Old 29th August 2007, 11:31 PM   #10
Cloth Ears's Avatar
You might want to try PHLs - the 3820 or the 4040 might match your top end. As to transparency that would have to be up to you to listen to them and see. But they'll be fast and accurate and about 96-98dB efficient with high power handling.
For the full range of sound, you'll still need a subwoofer, as even these won't be accurate much below 50Hz - I think you'll be pushing to get anything that can keep up with the Heils AND do the full 20-800Hz range.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
800hz - 16khz 1" CD under 150 is it possible? Jerry Parker Multi-Way 18 2nd August 2008 12:25 AM
Lower rails for lower impedance? 95Honda Solid State 7 19th December 2007 08:59 AM
best open baffle midrange 160-800hz thadman Multi-Way 12 15th June 2007 04:59 AM
how to lower the Fs of a driver Puggie Subwoofers 15 3rd November 2005 10:54 PM
Modifying a driver for lower Fs DeonC Multi-Way 4 22nd April 2004 03:03 AM
Page generated in 0.11313 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
