I bought bad Mission 753's, T's and x-overs fried, worth fixing?
Old 5th November 2009, 09:30 PM   #61
vincent.mester is offline vincent.mester
does any one know where i can get crossover parst for my mission 753 thay both burned out at the same time had them running for about 4 hours turned up loud but no where near max they suddenly went quiet any how all the power had gone i thought at first i had damaged the amp with them going at the same time i checked the crossovers and both must have over heated. theres a horrid mid to top sound when i play them but no punch or bass....the drivers are ok checked em... how do i fix this where can i buy the whole xover unit can any one advise thanks
Old 5th November 2009, 11:12 PM   #62
Inductor is offline Inductor  Portugal
Inductor's Avatar
Of course you should get a problem (I'm guessing here) with to much power, with that 2,2R resistor in series(?) with the woofers. How much W was that a 5W or 10W, and how much you were using from the amp? Now I'm just giving my hint, and possible you have more failed components.
You can buy new xovers, or try to repair it if you have some experience.
(If you are going to post a lot then build a new "Mission 753 xover repair" thread)
Old 5th November 2009, 11:57 PM   #63
Default 753 xover
thanks for your reply any idea where i could buy a matching xover the whole thing i did have some watts pumping but not loud enough to damage the drives i had wharfdales for years never had this problem.. i like the missions but blahhhh scare me now. maybe for party i should get diferent speakers hook em up for the party and then put my missions back on after wards
Old 6th November 2009, 10:36 AM   #64
Inductor's Avatar
Buy the parts from Mission if you can (or another) and for more power change the (7W?) factory power resistors. (Now, the resistors might be acting as a protection, but that is another story - and is not good for the quality of sound.)
Old 6th March 2010, 02:11 PM   #65
Default mission 753 crossover no high freqeuncy
hi thanks for replys so far can any one confirm that i have a crossover problem and its not down to my drivers i bought some crossovers off ebay 753 but i put them in my speakers and the the seem to have the same problem as my previous ones i just get a muffeld bass sound there seems to be hardly any mid and no top sound... when i attach just the high freqeuncy from my amp theres no sound when i attach to the low freqeuncy terminals i get a unresponsive bass ... i did a test i skipped out a section of caps and wires ..i wired direct from the high freq + direct to the red speaker out and i actually got a reasonable sound with top mid and a lively bass however not perfect by any means but acceptible .... so im not good with these xrosovers can any one help is it the crossover damaged or some thing else
Old 9th March 2010, 12:05 PM   #66
hi me again found that my mission 753 tweeters are blown ..... i put some cheap rubbish replacments on just to test.... so now the crossovers are giving me the high frequency and low but the 4 drives all sound the same dull bass the mid sound voice clarity doesnt seem to be there...... does this mean the mid range part of the crossover is damaged ????
Old 10th March 2010, 02:32 AM   #67
Inductor's Avatar
Good question... something is wrong.
Old 10th March 2010, 10:54 PM   #68
Default new crossovers 753
well i have orded some crossovers for my mission 753s a pair £120... and orderd some tweeters DT-284s a pair so this has got to fix em expensive but really too much messing about trying to discover which part of my crossovers are mashed.....i have no heart listning to music on bad speakers......i just hope that all my drives are ok im pretty sure they are could a bought a modern set for the amount i paid in total
Old 11th March 2010, 11:11 PM   #69
Default crossovers
hi yes some thing i ment i have the high freq through the test tweeters and i have bass and low freq through the bottom 4 drives but the mid doesnt seem to be there .... i skipped out a part of the crossover near the bottom coil and the mid comes through so does this mean its the crossover or is there a problem with some of the drivers ? i hope this makes sence
Old 31st May 2010, 11:39 PM   #70
ZeroPlex is offline ZeroPlex
Hi guys,
Why does it state in all the older mission model manuals to not touch the high frequency drive fixings?
I can't see what harm it would do to check they are secure and if you ever had a problem with a tweeter, you'd obviously have to remove and replace it again.
Do they say not touch them incase you over-tighten and risk damaging/cracking the fixture?
Thanks.
I bought bad Mission 753's, T's and x-overs fried, worth fixing?Hide this!Advertise here!
Pioneer HT - worth fixing? Bluto Solid State 5 4th April 2008 08:41 PM
CAL CL-5 -- Worth Fixing? neddyboy Digital Source 0 29th May 2007 03:56 AM
Thiel bookshelf speakers, 1980's, Worth fixing up??? rurockn Multi-Way 3 3rd October 2006 03:07 AM
Mission 707 - worth repairing? balance Multi-Way 0 4th August 2005 11:43 PM
Worth fixing an old cd player ? Nay9 Digital Source 0 7th January 2003 02:45 PM
