Which 2nd order slope is preferred (or most common) in a PA enclosure (8 ohm 15 inch woofer + 8 ohm compression horn) linkwitz-riley, butterworth, or bessel? and Why?
I've done a search, but can't get a def. answer PS: obviously not meant for Audiophile listening, but for covering medium sized crowds, probably outdoors. |
#2 |
Hi oquela,
In my understanding of crossovers alignments, the Butterworth has its peaking lobe in a downward direction of 15 deg. This alignment would probably be best if the units were placed on stands that put them above the crowd. The Linkwitz alignment (0 deg peaking lobe) would produce better dispersion if the speakers are to be used level with the crowd or placed on the ground. This is assuming time aligned drivers however. Check out the link below. http://www.rane.com/note160.html
The more I learn the more I realize how much more I need to learn. |
#3 | ||
#4 | |
The Butterworth 2nd (BW2) order does not have an off-axis lobe, only the off-order BW has that. It does, however, have a 3db peak on-axis. The odd-order BW has the off-axis lobe, but it flat on-axis. Listening on the lobe axis would actually not be recommended due to the lobe (a peaking on that axis). The Linkwitz-Riley 2nd order (LR2) would more likely provide a more even response due no on- nor off-axis lobing. There will be a small difference in the overall power response vs. the BW2, but I'm not sure that the difference will be very large. The Bessel, IIRC, will have less total group delay, but I'm not convinced that it's audible. It also does not have a flat summed response, but the difference there, again, may not be very audible if done well. In the end, I would suggest an LR2. Considering as well the large woofer (15") with only one other driver, the horn, you'll likely have a lot more trouble with the integration simply due to the widely disparate dispersion characteristics. The crossover type will probably be the least important issue, but I'd still not recommend the BW2 due to it's on-axis peaking. Dave |
#5 | |
I can't actually recall ever having seen a loudspeaker design by anyone using the BW2. Back before the Linkwitz-Riley, there may have been some examples. I think that the odd-order BW was most common and in some cases the even-order Bessel were used. There were also, I believe, some BW4s around, but the legs of the crossover were adjusted to get an approximate on-axis flat response, a compromise. The power response in the crossover region would be altered n that case. It's all about tradeoffs. Dave |
#6 |
Thank you for the responses! very helpful. I'm leaning toward the LR x-over....will post back w/results.
#7 | |
| 1st order Passive Line Level Crossover + 2nd order Highpass? | alexclaber | Multi-Way | 11 | 4th January 2008 07:15 PM |
| deceptive perception ? 1st order-2nd order question | poldus | Multi-Way | 4 | 10th April 2007 11:58 PM |
| My 1st order butterworth filter better than 4th order L-R: Why? | philipreji | Solid State | 61 | 1st March 2007 04:50 PM |
| 2nd Order Tweeter + 3rd Order Woofer = OK? | Jay | Multi-Way | 3 | 12th September 2005 12:12 PM |
| 1st order ? L-R 2nd order? or transient perfect?? | Ken L | Multi-Way | 6 | 17th October 2003 04:22 PM |
| Page generated in 0.11406 seconds (80.71% PHP - 19.29% MySQL) with 10 queries |
