Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 27th August 2007, 10:54 AM   #1
RobWells's Avatar
Default Altec drivers for 511B horns?
Is there a generally accepted pecking order for the Altec drivers for the 511B horns ?
Searches suggest the 802 series are better than the 808, but there are loads of different versions and its getting confusing.
My application would be running 500Hz up over 15" midbass horns. I also have some beyma 380 cd's on a 90 x 40 horn that could do tweeter duties if need be. XO is behringer digital, slopes from 6dB to 48dB available, as is PEQ.
Thanks,
Rob.
Old 27th August 2007, 11:49 AM   #2
chops is offline chops
chops's Avatar
I use the 902-8B and 8T.
Old 27th August 2007, 01:01 PM   #3
GM is offline GM
GM's Avatar
http://www.wmeckle.com/INTRO/SMALL/Altec.htm
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th August 2007, 01:39 PM   #4
RobWells's Avatar
Thank you both.
Rob
Old 27th August 2007, 10:29 PM   #5
I use 802D.
I'd love to hear from someone who's done side by side comparison with 902-8B.
Old 28th August 2007, 02:58 AM   #6
chops's Avatar
Originally posted by Evenharmonics
I use 802D.
I think my brother might have one in the trunk of his car! It's the hammertone green as well as the 511B that it's attached to.
I'll have to measure the VC with a multimeter and see if it's any good still, then try it out on my system.
BTW, he has this horn/driver in his trunk because one of his friends wants him to sell it on eBay for him, but still hasn't brought my brother the second horn/driver yet. It's a shame really, because he also has the two A7 cabinets as well, but they were sitting in 2 feet of water and are beyond repair. Hmm... I'll have to check and see if the woofers and xover s are still in them.
Old 28th August 2007, 02:38 PM   #7
GM is offline GM
GM's Avatar
Greets!
More good info I forgot to post: http://web.archive.org/web/200411110...com/altec.html
GM
Old 28th August 2007, 02:58 PM   #8
GM is offline GM
GM's Avatar
I use 802D.
Greets!
I've A/B'd them on much modded 511s way back when, but the 802D has more bottom end and rolled off top end compared to the 902, which among other things was redesigned for a flatter response and more top end 'air' when driven with a vanishingly low output impedance (SS) amp. The trade-off is a higher XO point is required with the 511 for best performance.
Tom Danley measured 802D/stock 511:
GM
Old 28th August 2007, 02:59 PM   #9
GM is offline GM
GM's Avatar
902/511 (sorry, forgot to record who measured it):
Old 28th August 2007, 03:23 PM   #10
GM is offline GM
GM's Avatar
Default Re: Altec drivers for 511B horns?
Thanks,
Rob.
Greets!
Got a little more time today to respond........ 807, 808 (~2.2 dB more eff.) prosound drivers are 806/802 HIFI units with high power Symbiotik diaphragms, so should only be used when XOing to a super tweeter in a HIFI/HT app due to its harsh, excessively rolled off top end. Indeed, some Altec 'faithful' contend that this one is preferred since it sounds a bit more the 1.4" large format driver down low, but I never tried it, so can't offer an opinion. Makes sense though and its usually available for much less than the various HIFI units.
FWIW, mine are '808' with Altec's original ultra-light diaphragms and the only way I'd consider upgrading is with these in Tangerine phase plugged 802-8Gs, though even when I still had good HF hearing the difference was subtle at best, so would be a complete waste of time/$$ for most adult males and I learned the hard way that a typical female's superior HF hearing prefers a rolled off response if not ultra clean with a sharp HF cut-off above ~18 kHz.
GM
Thread Tools
Altec 811B horns and Altec 414z 12" Speakers xecluded Swap Meet 0 21st September 2008 05:21 AM
FS: Altec 511B/902-8 and Usher Audio drivers!!!! chops Swap Meet 13 19th March 2008 03:47 AM
OB bass bin for Altec 511B/902-8B combo... chops Full Range 32 7th December 2006 08:19 PM
What is the cut off frequency for the Altec A7 and A4 horns? Cal Weldon Multi-Way 11 21st January 2004 12:06 AM
Page generated in 0.09524298 seconds (80.98% PHP - 19.02% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
