Old 26th August 2007, 11:04 PM   #1
Default hybrid p a speakers
hi,
Anyone have an idea about a diy p a "type" speaker?
Of course I can't just be normal and buy a commercial set.
I am a guitarist and want to build a set of speakers that I can use with my amp modeler for small jazz gigs. I use this stomp box when I am touring and play through the p a. It sounds great and is versitile (don't tell my amp tech who did a ton of mods on my class A tube amp).
I want to make this small and full range so I can use it for a synthisis project I am working with. Also P A speakers don't really cut it with fidelity.
My idea (tell me if I am crazy) 2 8inch woofers like maybe the dayton classic, a 5 /4 mid and 2 small tweeters . This could give it a small footprint for small cafes and just be loud enough to cut a small gig...and I could play snthisized music through them at moderate levels..
I hate to go with regular p a speakers..What do you think?
Old 26th August 2007, 11:52 PM   #2
Speakerholic
Cal Weldon's Avatar
I believe that to do PA, you use PA speakers. That's what they are built for. Hi-Fi drivers aren't up to the task. Do you have a design in mind?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 27th August 2007, 12:06 AM   #3
Default design?
Hi thanks for th reply.
Well I want to build this small...or at least a small foot print.
I am thinking muliple small cones rather than the typical 12 or 15 inch two ways that are everywhere. 4 6/12s per speaker? 2 8s? 2 10s?
This would make them at least narrow so they can be on a stage in a cafe and mabye have enough surface area to move a little air.
The tweeters are a problem with professional speakers. They are harsh I think..Any suggestions?
Old 27th August 2007, 03:38 PM   #4
Speakerholic
Cal Weldon's Avatar
The higher the frequency, the harder it is to integrate multiple units. Four woofers are ok but you'll want to stick to one tweeter. If you use 4 - 8", they should go high enough to XO to a tweeter. I'm short on time this morning but can have a look at units when I return. Have you browsed through any online catalogues yet?
Old 27th August 2007, 04:01 PM   #5
tinitus is offline tinitus  Europe
This 10" Eminence Legend B102 is used in a "highend" speaker(modified)
With 4 of them in an array with tweeter(horn) you will get a relative small footprint, good efficiency and power handling and maintain 8ohm impedanse, and I suppose with ok fidelity
http://www.partsexpress.com/pe/pshow...Number=290-495
Dont even think of a 3way
BTW, there is also ToneTubbys with 16ohm so you can paralel a pair and still use tubeamps - they are designed fore "open back"
http://www.tonetubby.com/speaker.htm
Old 27th August 2007, 05:09 PM   #6
Saturnus's Avatar
I'd say make a WHW with two good 10" woofers, and a good high/mid horn. 10"ers in my opinion offers the best compromise between sound fidelity and sound pressure. You might have to augment it with a subwoofer though, and for that I'd recommend two push pull coupled 15"ers with a wave guide front.
Yaqin VK-2100 hybrid running 4 ohm speakers Rockmore Tubes / Valves 2 9th April 2012 01:55 PM
Hybrid Car Amp... let's try jeppix Car Audio 19 18th August 2008 05:48 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
Final 0.4 hybrid ESL electrostatic speakers affordablehifi Planars & Exotics 3 24th March 2005 09:20 PM
Zen V5 hybrid MIKET Pass Labs 5 1st August 2003 07:37 AM
Page generated in 0.09129 seconds (75.58% PHP - 24.42% MySQL) with 10 queries
