I have build me speakers, using Fostex fullrange fe 126e.. It sounds great with my super t-amp.. This system have it's own room, I tried first to have it on my main soundroom, but it was too big, now in the small room it sounds great.
http://www.hifisentralen.no/forum/in....0;attach=4807 http://www.hifisentralen.no/forum/in....0;attach=4805 |
#2 |
frugal-phile(tm)
You don't often see FE126 in a BR... can you give us some detail?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I love this sound, it`s not hard on the topp, it has a fullness sound, and it's wery cheap (49 euro) each element.
I have a linkthis link.. |
#4 |
Looks great!
Is that built to the Fostex Recommended Bass Reflex Enclosure size? How do you like the bass response and are you using a BSC?
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#5 |
This is the recommendation from fostex yes!
I dont know what a bsc is (bad english) The bass reponse is good on this one |
#6 |
BSC = Baffle Step Correction
http://www.quarter-wave.com/General/BSC_Sizing.pdf Attached is a quick sim of the fostex BR enclosure. Based on the sim results, I would guess that an aggressive BSC could help.
#7 |
Oh! I see, in that case i dont use it no.. It's just plug and play
#8 |
Hello Everybody,
I 'm starting to build Frugal Horn(full version but without wedgies) with FE126E and I would like to know if BSC is applicable to this project or is only applicable on BR system. Thanks Richard. |
#9 |
I don't have bcs on my speakers, and I don't think bass is a problem on mine one..
#10 | |
Richard, with the supra-baffle (which I personally consider a critical component of both the FrugalHorn and Ron Clarke's A126), baffle step EQ should be redundant.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| Recommendations for a tweeter for Fostex fe-126e? | boidos | Full Range | 11 | 1st July 2009 04:45 AM |
| Fostex 126e or 127e | germpod | Full Range | 71 | 9th May 2008 07:26 PM |
| Building Fostex 126E Help needed | ddmddm | Full Range | 1 | 16th December 2005 05:44 AM |
| Fostex 126e response (10,5 liter BR) | Juspur | Full Range | 0 | 2nd February 2005 07:18 PM |
| Page generated in 0.10383 seconds (74.15% PHP - 25.85% MySQL) with 11 queries |
