Old 23rd August 2007, 08:47 PM   #1
Default Best way to DIY a 2.1 system
I'd like to make Zaph's newest project, but I also want some deeper bass extension. What's the best way to cross over to a mono sub?
Howard
Old 23rd August 2007, 10:49 PM   #2
peter_m is offline peter_m  Canada
As Zaph states it in most of his projects, the best is with an active x-over to an amplified sub. You can find some stereo amplifiers/receivers that have it built-in and ALL 5.1 HT amplifiers/receivers have it. They usually have a setting to go 2.1 instead of the standard 2.0 and 5.1
Peter
Old 23rd August 2007, 11:15 PM   #3
Timn8ter's Avatar
Also, most plate amplfiers now have high level in and out connections. These will typically have a 6db active XO tied to them.
Marchand Electronics has active XO kits and Creative Sound has a bass management device they are offering with the purchase of certain woofers.
The Outlaw RR2150 is a 2.1 receiver if you're in the market for such a thing.
Old 24th August 2007, 02:58 AM   #4
Are there any free plans for an active stereo->mono crossover?
Old 24th August 2007, 03:35 AM   #5
Preferably simple, as well. I'm not too concerned about absolute sound quality.
Old 24th August 2007, 06:03 AM   #6
Rod Elliot's site has a LR2/LR4 component calculator. You can then use PCBExpress to draw it up.
Old 24th August 2007, 10:15 AM   #7
There are various "best" ways of doing it.
Build the ZBM4 less deep - around 4 litres sealed and stuffed.
1) Then use a subwoofer with your amplifier outputs.
2) Or if you can split output from the preamp - reduce the input
capacitor values of the speakers power amplifier to roll-off
low bass - pre-amp to the subwoofers low level inputs -
sub converts stereo to mono.
2+) You could modify the power amplifiers feedback loop
such that it forms a 2nd order high pass filter - L/R.
Drive from split output of the preamp.
For 2 driver rolloff is overdamped 3rd order for 2+ if you set
frequency to around 85Hz = near 4th order L/R at 85Hz.
So for 2+ ideally you need a sub plate amplifier with 4th order
L/R roll-off.
/sreten.
Old 24th August 2007, 12:22 PM   #8
audiobomber's Avatar
Build the main speakers in a sealed cabinet. Insert a pair of 100 Hz high-pass Fmod filters on the inputs of the amp driving the mains. The second preamp feed goes to a sub with an LR4 low-pass filter. The Fmod filters are very inexpensive, but they sound pretty transparent and they do the job.
http://www.partsexpress.com/webpage....nufacturer=265
Dan
What's your system looking like right now? jduffy Chip Amps 1 5th May 2008 08:38 AM
Help with PSU for Tri-Amp System snax Power Supplies 9 16th July 2007 08:17 PM
Dj System GOWA Multi-Way 5 6th July 2007 03:57 PM
Keep RFI out of your system? I_Forgot Everything Else 3 5th July 2007 02:34 AM
PIC Of My system in the car Dj BASS AMP Car Audio 10 10th January 2004 10:38 AM
Page generated in 0.11707 seconds (76.69% PHP - 23.31% MySQL) with 10 queries
