Can someone tell me or direct me to information about 2.5 way crossovers? Thanks.
peace, memphissound <>< |
#2 |
To understand the use of a 0.5 woofer, you have to understand baffle step as the 0.5 woofer provides correction for these losses. Have a read of these as will give you some background.
http://www.t-linespeakers.org/tech/b...intro-bds.html Box designs that address baffle step? Baffle step correction circuit - how to design? I've found it's best to crossover the 0.5 woofer between 150Hz - 200Hz for a box width around 200mm. All you need is a 1st order crossover using a single inductor to the 0.5 woofer. The inductor value is calculated using the impedance at the crossover frequency and not the nominal impedance of the woofer. For other box widths, I use this fudged forumula that was derived from tests. 0.5 woofer crossover freq = (115/baffle width in metres)/3.1416 If you find you are getting too much BSC you can reduce the woofer SPL with an L-Pad. |
#3 |
Thanks for the info.
I tried a couple of "Searches" but could figure out the right stuff to put in for the terms. peace, memphissound <>< |
#4 | |
Why couldn't you use the same low pass crossover for the .5 woofer as for the main woofer? (wire in parallel) |
#5 | |
diyAudio Chief Moderator
#6 | |
The other woofer would be crossing over at a higher frequency such as 3000Hz and you don't want the 0.5 woofer crossing over there or you end up with a pseudo MTM. If you wire it in parallel to the other woofer, the impedance is halved and the existing crossover is cactus. I've found that a gentle 1st order crossover works best for the 0.5 woofer and I crossover at about a third of the baffle step F3 frequency. This way you don't get a boost above that F3 when combined with the main woofer. |
#7 |
Krutke thinks that it makes fore a better phase if the 0.5 woofer is connected through/after the "fullrange" woofer
http://www.zaphaudio.com/Waveguidetmm.html |
#8 | |
A series resistor does have an effect and how much of course depends on the amount of attenuation. I take advantage the series resistor altering the Qts for OB use. http://www.diysubwoofers.org/dipole/design.htm |
#9 |
So everything must follow a master plan. You adjust as an afterthought, it takes yet another alteration. That was my point.
#10 |
You are right. Good planning is the key and have to be very methodical for good results.
| Crossover for vifa 2 way setup - how can I find out what this crossover is doing? | Tino | Multi-Way | 11 | 17th May 2009 04:21 AM |
| Help me with a crossover. | raypalmer | Multi-Way | 4 | 5th April 2009 01:48 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Crossover help please :) | Tenson | Multi-Way | 17 | 15th April 2006 09:34 AM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Page generated in 0.12053 seconds (78.45% PHP - 21.55% MySQL) with 10 queries |
