Old 23rd August 2007, 05:01 PM   #1
herm is offline herm  United States
Default Parts Express H12RW waveguide
Has anyone tried this waveguide? It's practically free.
I have been reading too much of the Gedlee and Lynn Olson threads
lately.
They have me thinking I should give these compression drivers and
high efficiency pro-sound drivers a try!
I'll probably stick with the B&C compression driver like Dr. Geddes used
in the Summa, so that I can upgrade to his waveguides and foam
blocks later...
herm
Old 23rd August 2007, 05:27 PM   #2
Saturnus's Avatar
I haven't yet but I have been considering buying a couple to chop off the mounting end and mount some small full-range driver instead.
Old 24th August 2007, 10:45 PM   #3
Brett's Avatar
They look OK, and the price is definitely excellent. Pity PE won't post stuff here and UPS is too expensive.
The B&C's Geddes uses are bolt on IIRC, so you'll possibly need an adaptor.
Old 25th August 2007, 12:39 AM   #4
Bolt-on? Well that's annoying.
Why don't any of the vendors show the business end of the
compression drivers?
Any recommendation on a decent screw type?
And while we are at it, does the bolt-on adapter change things?
Old 25th August 2007, 12:47 AM   #5
DougL is offline DougL  United States
The adapters are inexpensive.
Under $10 at Parts Express.
http://www.partsexpress.com/pe/showd...number=264-322
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 25th August 2007, 12:54 AM   #6
Thanks for the education, Doug & Brett.
herm
Old 25th August 2007, 03:21 AM   #7
Brett's Avatar
Because it'll state in the spec sheet what type of mounting it uses.
BMS 4540
Depending on the adaptor, flare and driver, there can be discontinuities in the profile that can affect sonics. I don't like them.
Old 25th August 2007, 05:11 PM   #8
More questions, if you guys don't mind:
The waveguide is somewhere near 12 inches across,
which should allow extension to 1200 hertz or so.
(13540/12=1128)
I was just looking at the BMS 4550 and 4552ND, and
they allow a little lower crossover than the BMS 4540.
Any real advantage here? I was just looking at possible
woofers, and it looks like I would be better off crossing
as low as possible.
Just an FYI, this will be home use, so I will NEVER push
the drivers hard (unless I want my ears to bleed).
I am looking forward to trying efficient speakers...
herm
Old 25th August 2007, 05:26 PM   #9
tinitus is online now tinitus  Europe
You want efficiency but wont push them very hard ....
I have been looking at Supravox 165GMF with the small horn TW2-20, or maybe a nice ribbon, the 165GMF could be mounted in a fronthorn/waveguide too
but it will need a sub or something ... I am planning on a 6th order bandpass sub, cant resist on trying
Old 25th August 2007, 10:52 PM   #10
Brett's Avatar
as low as possible.
If it were my money being spent, then I'd go for the 4552 as I think it'd have less distortion at the bottom of the passband in this instance. I don't like running any driver right to the edge of it's passband.
Parts Express - UK Equivalent? wilky Multi-Way 4 7th September 2008 08:32 PM
parts express alternative tareqx2 Multi-Way 7 29th August 2007 04:01 AM
LM3886 @ Parts Express!! troystg Chip Amps 6 6th April 2005 03:11 PM
parts express ! onis_uk Multi-Way 9 7th August 2004 01:56 AM
Page generated in 0.10260 seconds (78.59% PHP - 21.41% MySQL) with 10 queries
