Old 22nd August 2007, 02:08 PM   #1
audiobomber's Avatar
Default Calculate PLLXO
I purchased an XM46SB passive line-level crossover from Marchand; 80 Hz BW2 high pass. The circuit is shown in the manual:
http://www.marchandelec.com/ftp/xm46man.pdf
The input impedance of my power amp is 22K. When I told that to Phil, he said it doesn't matter. I don't get it. Wouldn't the amp's impedance affect the XO frequency? The supplied component values are:
R1 = 2.55k
L1 = 5.6 H
C1 = 0.47 uf
C2 = 0.22 uf
(C1 + C2 = 0.7uf actual, according to the written notes in my manual).
I'd like to adjust the component values to make it possibly more accurate. At the same time, I'd like to use a pair of .33uf Auricaps I have lying around. The inductor value can't change, but I could easily change R1 and the caps. Can someone please help tweak this circuit?
Dan
Old 22nd August 2007, 03:31 PM   #2
You have not specified R2. R1 and R2 make the filter fairly
tolerant of load impedance and normal source impedances.
Absolute accuracy of 80Hz high pass 24dB/oct (should be L/R)
is not necessary if you have an adjustable 24dB/oct low pass
on the subwoofer.
Careful speaker + sub placement + sub adjustment will be needed.
Theoretically you need a 22K resistor on the output (no level adj.)
/sreten.
Old 22nd August 2007, 03:55 PM   #3
on the subwoofer.
/sreten.
Hi sreten.
There's only one resistor, R1. Note that this is a 2nd order Butterworth, high pass only. The high pass filter combines with the natural roll-off of my sealed BESL MTM's to provide 24 dB slope.
This is for a stereo system, where the dual subs are placed directly below the main monitors. I know absolute accuracy is not strictly needed, but I want to upgrade the caps, and if I'm going to do that, I might as well try to improve the crossover point as well.
/sreten.
I'm not sure what you mean. There is no pot in my crossover. R1 is 2.55K, and my amp impedance is 22K. Which means I have a total impedance of 2.285K. If I plug the numbers into the formula, I get a -3dB point of 65 Hz due to the inductance, and a -3dB point of 100 Hz for the caps.
Shouldn't I change R1 and the caps so that I get -3dB at 80 Hz for both legs?
Dan
Old 22nd August 2007, 04:45 PM   #4
So your using half of the board twice ? C1 = C1a, C2 = C1b.
....... BW2 = butterworth 2nd order
7uF + 5.6H with zero source impedance and 2Kohm load = 80Hz BW2.
You cannot treat each component seperately. Reduce R1.
Find an on-line BW2 calculator to play with values.
/sreten.
Old 22nd August 2007, 05:16 PM   #5
C1 = C1a, C2 = C1b
Oops, yes, sorry for confusing the issue.
Dan
Old 22nd August 2007, 05:34 PM   #6
This looks like a good calculator: http://www.the12volt.com/caraudio/crosscalc.asp#cc
Dan
PLLXO (v AXO v PXO) benefits/ Model? rick57 Multi-Way 42 9th August 2011 11:12 PM
Pedja Rogic buffer + pllxo joshuajoshua Chip Amps 0 31st January 2009 05:32 AM
Using phono input with PLLXO mashaffer Subwoofers 0 13th August 2007 11:36 PM
PLLXO high pass Soulwax Multi-Way 8 6th May 2005 12:40 AM
PLLXO driven by Sonic impact - HOW? ThomasS Class D 4 5th April 2005 10:08 AM
Page generated in 0.09066 seconds (76.70% PHP - 23.30% MySQL) with 10 queries
