Old 22nd August 2007, 01:12 PM   #1
freddi is offline freddi  United States
freddi's Avatar
Default Karlson HF waveguide tweeter lens
Karlson's open ended waveguide antenna is one of my favorite high frequency lens and can present a wide, high and natural sounding soundfield.
A 5.3"-5.5" half-ellipse tube made of 1" ID pvc will work well. This is roughly the size of Walter Zintz's Transylvania Power Company "The Tube". ("The Tube" had 2 degree down-sloping walls and a different aperature)
Karlson's X15 tube from ~1966 had a diameter transition giving a graph notch at ~2K2Hz and ~holographic sound (try playing a good recording of a rain storm)
1 inch ID tube angled ~ 30 degrees up on a X15 size coupler
http://img405.imageshack.us/img405/3...nx154ozpm0.jpg
1.875" ID x 9" Karlson tube on an 18" coupler angled 30 degrees down
http://img233.imageshack.us/img233/3402/9tubege8.jpg
1" ID half-ellipse tubes of schedule 40 before filing and sanding
http://img479.imageshack.us/img479/7890/thick17ky.jpg
Graph at 30 degrees tilt with CD8 of 1" tube vs a 9" tube with diameter transition(s) CD8 was limited to ~12Khz
http://home.earthlink.net/~buddhaboy2/9v7.jpg
Transylvania Power's Karlson tube "The Tube"
http://img457.imageshack.us/img457/7622/tt6wb.jpg
X15 tube replica 1.875" x 7.25"
http://home.earthlink.net/~buddhaboy2/X15/X15Tube.jpg
Thinwall pvc half-ellipse tube
http://home.planet.nl/~ulfman/images...Tube1-Thin.jpg
a tweeter waveguide angeloitacare Multi-Way 3 19th July 2008 02:45 AM
Karlson "projectors" and HF waveguide tubes freddi Multi-Way 3 9th December 2007 09:47 PM
Tweeter waveguide now in AUS tktran303 Multi-Way 1 26th May 2007 03:00 AM
Helper tweeter lens via ~Karlson idea "THE KUP" freddi Full Range 0 25th November 2006 06:54 PM
Peerless HDT 100 tweeter for Karlson party speaker project bikehorn Multi-Way 6 6th February 2006 08:00 AM
Page generated in 0.07535 seconds (67.72% PHP - 32.28% MySQL) with 10 queries
