A friend of mine has a handicapped child. To help the kid enjoy his music without disturbing others, he was looking for something like this: http://www.sounddomes.com/20inch.htm Has any of you experience in using such a device (I understand they are used in shops and exhibitions). What would be involved to build one ourselves? Thanks for any help, Jan Didden
/Another new issue: Linear Audio Volume 3! |
#2 |
This would be an alternative:
http://www.sonus.de/php/p_produkte.php?produkt_id=302 |
#3 | |
![]() Back to on-topic: With the ones that I heard so far you can't talk of enjoying music. The sound was like telphone quality. I'd raher suggest either headphones or something that is meant for listening in the closefield. Narrow-beam radiation can also be done with arrays of small drivers if needed. The electrostatic solution looks good (apart from the LF reproduction) but I guess it might be quite expensive. Regards Charles |
#4 | |
Jan Didden
#5 |
We used that principle on an exhibition stand for EA games a good few years ago, only we had to get, (very expensive), custom made acrylic domes made. All you need is a parabolic section, I wonder if you could make something up using an old umbrella covered in paper mache or plaster impregnated bandages?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
I wonder if a couple of cases of plastic drinking straws stacked in front of the speakers would make them directional. leave the cardboard sides to hold the straws together, but remove top and bottom and stack on side to direct the sound forward only....
#7 |
Use a small satellite dish or a large mixing bowl. Very cheap reflectors.
A very small driver in a little box at the focal point would provide quite directional sound. The dish/ bowl could be painted with patterns, or white with one of those little motorized lamps shining on it. Remember bass is less directional, you may need to filter out the low frequencies to reduce the disturbance to others. |
| Waveguides for cones/domes | andy19191 | Multi-Way | 26 | 4th July 2009 01:49 AM |
| FS seas excels and ushers domes | trusound | Swap Meet | 1 | 29th August 2008 03:26 PM |
| FS: ATC Domes and Alphacore Coils | mgreene | Swap Meet | 14 | 18th July 2008 11:16 AM |
| FS: ATC SM75-150S midrange domes | Jussi | Swap Meet | 3 | 20th January 2006 10:51 AM |
| FS: ATC SM75-150S midrange domes | Jussi | Swap Meet | 1 | 20th January 2006 08:50 AM |
| Page generated in 0.09330 seconds (77.07% PHP - 22.93% MySQL) with 10 queries |
