Beyma 12CX - PA only of usable for hifi ?
Old 20th August 2007, 11:26 AM   #1
Empee is offline Empee  Netherlands
Empee's Avatar
Question Beyma 12CX - PA only of usable for hifi ?
Hi !
I'm thinking of buying Beyma 12CX co-axial speakers,
but I cannot seem to find any 'user-reviews' on the internet
I can however find stuff like guitar-cabs, PA-monitor use,
and some guys who have them in Karlson enclosures.
But are they usable as quality hi-fi speakers ?
I plan to use them on single ended triodes
If you have / had them, please tell me what you think of 'em,
and please tell me what cabinets you use(d)
Empee
In the end, all is good
If it's not good, it's not the end
Old 20th August 2007, 01:26 PM   #2
R.I.P.
According to the parameters around 3cuft tuned to 40Hz would work well.
Normal "PA" type crossovers will likely not compensate for baffle step.
Many "high efficiency" designs also ignore baffle step.
/sreten.
Old 20th August 2007, 01:56 PM   #3
Mikael Abdellah is offline Mikael Abdellah  Sweden
You might want to consider the Monacor SP-30PAX
Old 20th August 2007, 02:41 PM   #4
badman is offline badman  United States
badman's Avatar
Sreten- that's the nice way of putting it... I generally choose to use "Are liars" for those companies making 'high efficiency' speakers without BSC. That camp (commercially) includes such ilk as Zu, claiming 101 dB and extension to 30Hz out of a couple cubic feet....
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 14th August 2014, 10:08 PM   #5
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
There is someone that already listen this Beyma 12CX driver??
It is good for hi-fi??
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 15th August 2014, 08:39 AM   #6
gafhenderson is offline gafhenderson  United Kingdom
Depends how sensitive you are to 3rd order distortion. Not heard one yet that doesn't screech from the compression unit right around the usual cross over region. The 8" Beyma that is used in the dynamikks monitor 8 is relatively cheap and demodulated but has less of the ear bleeding distortion
.Beyma 8CX300Nd/N 8" Coaxial Driver from Beyma 188.36
Old 15th August 2014, 10:53 AM   #7
peterbrorsson is offline peterbrorsson  Sweden
12XA30Nd Nofrills Edition |
...supposed to sound nice though slightly modified in the chamber and compr. driver diaphragm exchanged...
Old 15th August 2014, 11:34 AM   #8
Adolf Corkscrew is offline Adolf Corkscrew  Finland
I haven't heard this driver, but judging from the datasheet only the raw responses from the drivers seem a bit problematic for Hi-Fi use. The tweeters response falls too early to be crossed over low enough to the 12" midrange.
In order to achieve reasonable off-axis response you generally need to cross these large coaxials in the 1-1.5 kHz region.
If you want a ridiculously cheap and acceptably sensitive 12" coaxial, the finnish website audiovideo.fi recently published a series of DIY-loudspeakers based on the Eminence Beta coaxials, including the 12" Beta 12CX, which also gave the best sound quality of them all. I haven't yet heard this, but the editor told me it is surprisingly good sounding.
For something a bit more exotic (read: expensive) I've had quite good results with the BMS 12C362, but I will not recommend it until I've heard it head on with the Eminence, costing about a quarter of the BMS's price. I want to know whether the BMS really justifies spending the extra dosh.
Old 15th August 2014, 12:00 PM   #9
sangram is offline sangram  India
As one example, Emerald Physics uses the driver in the CS2.7, which is in itself an upgrade from the CS2.3, which uses the Beta 12CX.
I've heard both and I prefer the Beyma. It has slightly lower distortion, IINM because it sounds smoother. Unfortunately this driver does not work on open baffle without bass support as the Q is too low (thus the absence of an upgrade to the CS3.0 which continues to use the Beta). Both speakers use a custom crossover between the drivers, and I could certainly not hear anything that indicated very high levels of distortion. I suspect some crossover work is necessary to get the best out of these.
The Eminence driver is good too, but the APT50 is even worse than the Beyma's compression driver wrt a low crossover point, it does not like to be crossed below 3k, ideally 4k. This can be somewhat avoided by using a different compression driver.
Both have the nasty 10k dip inherent to these kind of coaxials due to the discontinuity in the throat. There is some EQ required to smooth response of both drivers, the EP speakers are accompanied by a Behringer DCX 24/96 for this purpose.
The big advantage of the Beta is that you can buy it (at least here) without the compression driver and use one of your choosing. For the Beyma, it comes pre-fitted and sold as a single driver unit.
Old 15th August 2014, 12:35 PM   #10
Still surprisingly the designer was able to cross the APT50 at a low enough crossover point for the 12". And the crossover region looks quite clean. The big dip centered at around 8kHz is still there, of course, but is absent from the off-axis response, which is probably what saves the sound in real life listening.
It's only in finnish, though, but you can find the crossovers and responses from here:
Kaiutinrakennusohje Yksisilmäiset veljekset - hifi-PA-kaiuttimet Eminence Beta-8CX, Beta-10CX ja Beta-12CX -koaksiaalielementeistä | AudioVideo.fi
Google translate usually makes only miserable gobbledigook trying to translate anything finnish, so I might also answer questions.
As I said, I've yet to hear the outcome in real life, but apparently they sound nice.
Regarding those dips in the treble response, the BMS I mentioned is probably the cleanest driver I've ever measured in that respect. Noticeably cleaner than the Seas 6,5" coaxial. Only minor dips here and there, but they're quite shallow and narrow. Oh, and it's one of the few drivers I've encountered that measures actually better than the datasheet suggests.
Beyma 12CX - PA only of usable for hifi ?Hide this!Advertise here!
Beyma 12CX in a MLTL? G Full Range 3 10th February 2007 02:43 PM
Anyone using the Beyma 12CX in a MLTL? G Multi-Way 1 8th February 2007 01:47 AM
Enclosure for Beyma 12CX - whats good? freddi Full Range 0 24th November 2006 05:12 PM
Please suggest replacements for Eminence Beta 12CX Saurav Multi-Way 9 20th May 2004 04:27 PM
car amp usable as sub-amp? DIY_Peter Multi-Way 4 12th April 2003 06:29 PM
