diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Receivers vs amps. (http://www.diyaudio.com/forums/multi-way/107173-receivers-vs-amps.html)
bizza 20th August 2007 02:39 AM
Receivers vs amps.
What is the difference??
Cal Weldon 20th August 2007 03:04 AM
A receiver has a tuner, an amp does not.
bizza 20th August 2007 03:32 AM
That was pretty straightforward, thanks.
Nanook 20th August 2007 07:26 AM
er ..ok,
and an intergrated amp has a power amp and preamp in one chassis.
think of it this way:
a line stage has no phono stage ("head amp"), it's only a means to change the input and "volume" to a power amp
a phono stage is required to reverse the RIAA recording curve, the industry standard in vinyl. A MM stage has less gain than an MC stage because the MM output is much more than a MC
a preamp is unable to drive speakers, it's only a means to change the input to a power amp, and switch sources and a phono stage (usually, but not always)
a (power) amp has no controls, just amplification stage(s), and high power output to drive the loudspeakers
amp+ preamp (whether preamp or line stage) = intergrated amp
intergrated amp + tuner = receiver
Resources saved on this page: MySQL 18.75%
