Old 18th August 2007, 06:20 AM   #1
REM is offline REM  United States
Default Baffle step Question for unusual enclosure
HI all. I want to experiment with small drivers mounted at the end of a PVC pipe.Will baffle step comp need to be changed relative to a coventional box? Also will the low end rolloff be affected also?This is my first post here, I see some very talented poeple post here.Thanks...
Old 18th August 2007, 08:55 AM   #2
ashok's Avatar
Your baffle is the size of your driver !
AM
Old 18th August 2007, 09:06 AM   #3
Svein_B is offline Svein_B  Norway
Download THE EDGE baffle difraction simulator from
http://www.tolvan.com/edge/help.htm
Then you can play with different baffle sizes and shapes.
For the effect of different enclosure shapes, here is a page from a report published in 1936!
SveinB
Old 18th August 2007, 09:51 AM   #4
Svante is offline Svante  Sweden
Svante's Avatar
Yes, if the speaker is directed towards the listener, this baffle shape is not principally different than any other baffle shape. This one is just circular.
One thing that I fint interesting with circular baffles, though, is that they behave very differently depending on how large proportion of the surface that is covered by the driver. This can be clearly seen in the The Edge sim below.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 18th August 2007, 07:31 PM   #5
frugal-phile(tm)
planet10's Avatar
Harry F Olson, Acoustical Engineering, May 1957
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Bandpass Enclosure & Baffle Step 69stingray Multi-Way 2 12th July 2007 01:02 AM
Baffle Step question mazeroth Multi-Way 12 24th January 2006 10:45 PM
baffle step basic question kneadle Multi-Way 11 18th July 2004 09:50 PM
question about building crossover with baffle step Jim85IROC Multi-Way 1 21st April 2004 03:45 PM
Noob question: baffle step compensation HeatMiser Multi-Way 7 24th June 2003 02:59 AM
Page generated in 0.09144 seconds (75.79% PHP - 24.21% MySQL) with 11 queries
