I have the plan to use 4 small (4.5") drivers per side spaced at 12.5cm from each other (center to center distance between each other, in two colums, each driver touching the others edge) and I was wondering at what frequency the combing effects could get me in to trouble. The drivers can go up to 9K, although I may not want to go that high. So, what should be the highest frequency of operation of the mids? How much do combing effects affect sound quality?
#2 |
Download THE EDGE baffle difraction simulator from
http://www.tolvan.com/edge/help.htm Then you can play with different configurations. The [simulated] effects are most noticeable above around 5K SveinB. |
#3 | |
2 x wavelength = 5440 Hz You want to cross over somewhere betwen these two frequencies (preferably closer to the lower number, though the actual value will depend on the actual degree of roll off from arraying them)
"Any fool can know. The point is to understand" - Albert Einstein |
#4 |
I advise against placing them in two closely spaced vertical columns of two drivers per column (or any other number). You will get azimuthal lobing. Place all four in one vertical clolumn as close together as you can get them. The actual characteristics of the driver will determine to a great extent how bad if at all the comb filtering will be.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#5 |
Thanks for your responses.
I have been playing with Egde,and I am a confused with it: increising the speaker source density high enough there is no more ripple/combing. The response changes drastically by increasing the number from 1 to 20.From what I see, 4 is renders the expected behavior. RCAVICTIM: thanks for your comment. How about a diagonal line of drivers going from one corner of the baffle (upper left) to another (lower right). This would allow for a shorter baffle. Acrually the response in Egde is better this way as configured in any vertical column. there is also this arrangement which models very flat and has less open baffle peak. It looks like this: ___ ....X| .X...| .X...| __X| There would e enough space to place the tweeter in the middle of the drivers, but then again this may lead to the problem rcavictim mentioned in the overlapping range, specially in low order crossovers are used. |
#6 |
One more question: should I expect 3dB extra from each additional mid driver?
#7 |
No, there is a limit to it all ... I think it is 3db every time you double the amount of drivers
#8 |
So, I double the first, +3db. Then I double the pair, +3dB again for a total gain of 6 dB respect to the base sensitivity of the first driver, right?
#9 |
Combing should be no problem here, because distance from drivers to listener will vary only by single centimeters if the listener is on axis.
| So now, combing isnt a problem in an array? | amt | Full Range | 146 | 13th April 2009 12:28 AM |
| WR125 combing with MTM or TMM | davidallancole | Multi-Way | 1 | 26th January 2008 12:11 AM |
| Seas Excel mids vs. dayton rs mids in dipole | sqlkev | Multi-Way | 2 | 10th July 2006 06:28 PM |
| Effect of multiple drivers on ideal box volume | hellomynameiswill | Multi-Way | 6 | 1st August 2001 02:26 PM |
| Page generated in 0.09675 seconds (80.77% PHP - 19.23% MySQL) with 10 queries |
