Is my crappy soldering satisfactory?
Old 17th August 2007, 10:25 AM   #1
wixy is offline wixy  Australia
Default Is my crappy soldering satisfactory?
I've just had my first attempt at soldering, attempting to solder my speaker cable to the terminals of my full range driver.
However, I didn't exactly do a fantastic job.
Could someone take a look at these pics and tell me if these solder joints are adequate enough?
http://img177.imageshack.us/img177/5...stex006xi3.jpg
http://img523.imageshack.us/img523/5...stex011ko8.jpg
Old 17th August 2007, 10:34 AM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Not great but I've seen worse. It should survive. It looks like a combination of technique and not enough power/tip area on the soldering iron.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 17th August 2007, 10:35 AM   #3
chipco3434 is offline chipco3434  United States
It will be fine. A lot of the full range gurus prefer much smaller wire size. Some have concluded that "Thin is in."
Old 17th August 2007, 11:48 AM   #4
acid_k2 is offline acid_k2  Italy
IMHO, soldering joints are not so good.
You need more heating!.
If you want, you could:
-use a more powerful soldering iron
-use more solder
-try heating the joints for 30 seconds or so... paying attention at the cables melting!
You have to consider a speaker like a souce of vibration, bad soldering joints usually breaks in a short time.
Old 17th August 2007, 12:04 PM   #5
Foxx510 is offline Foxx510  Australia
I'd have to say "just". With that rigid cable and not quite enough heat you might find you have a dry joint there soon. I would consider less cable if you can't get a hotter iron.
Old 17th August 2007, 04:13 PM   #6
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
The soldering job really doesn't look that bad
Gently tug/pry on the joint.
Does it break loose?
It shouldn't
Next time, heat the wires and apply solder on them alone until the wires are covered with solder.
The 'puddles' of solder will curve in when done right (concave).
After the wires have solder on them, then solder to the terminals.
Just practice
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 17th August 2007, 04:19 PM   #7
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally posted by myhrrhleine
Next time, heat the wires and apply solder on them alone until the wires are covered with solder. <snip> After the wires have solder on them, then solder to the terminals.
Agreed.
planet10 needs your help:
Let's help Ruth and Dave
Old 17th August 2007, 04:26 PM   #8
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Needs more solder! Copper shouldn't be visible
Old 17th August 2007, 09:43 PM   #9
Thanks guys! I'll give it another shot.
Old 18th August 2007, 12:05 AM   #10
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
That looks a hell of a lot better than my soldering jobs. I don't have an excuse either because I've been bodging soldering for a couple of years now
I'd be happy with that wixy.
Is my crappy soldering satisfactory?Hide this!Advertise here!
Why do manufacturers use crappy digital filters? John007 Digital Source 23 7th May 2008 06:54 AM
Boo!!!Crappy scams!!! seangoesbonk Everything Else 12 2nd February 2002 07:28 PM
Upgrading my crappy JBL's griff Multi-Way 0 23rd January 2002 09:53 PM
Copyright ©1999-2017 diyAudio
