I have a number of older Rockford Fosgate car stereo crossovers that look to have good, not great, components in them (air core inductors and poly caps). Without ripping these all apart to see what the values are, is there any way to test them to see what their crossover points are? Some of the caps I can see but, their is nothing on the inductors. I was thinking a series of sine waves and loading them with a 4ohm resistor and measuring the voltage at the resistor. I am clueless if this would work or if there would be a better alternative.
Thanks in advance, Ken |
#2 |
Did it Himself
They will be designed for specific speakers. Just rip them apart and use the parts in something else. You can work out the inductances with a sine wave and a load resistor.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
hi THUMP LUMP
You could: 0- search crossovers datasheet, or 1- buy un inductance meter (or a DMM with inductance meter), measure inductors and calcolate frequency, or 2- Buy a sinusoidal generator, a frequency meter, a linear amp, a resistive load and observe attenuation of voltage on the load... IMMO, if you want to know the value of inductance for re-using inductors, method 1 is the best... |
#4 |
If you have a PC with amplified soundcard, you can use some program (search with google) to create a sinusoidal tone. You may find (in the same way) a frequency-meter for soundcard.
| PG MS-2125 component values | toiletH20 | Car Audio | 6 | 22nd August 2008 07:46 AM |
| LM3886 PCB - component values? | vinnie | Chip Amps | 1 | 3rd April 2007 06:35 PM |
| What are the component values for ELF 1.5? | GarMan | Multi-Way | 1 | 27th June 2005 07:48 PM |
| Help! Preamplifier Component Values | androck | Solid State | 6 | 23rd March 2004 09:07 PM |
| Unknown inductors values | future | Parts | 1 | 30th May 2003 02:39 AM |
| Page generated in 0.07730 seconds (66.74% PHP - 33.26% MySQL) with 10 queries |
