Old 15th August 2007, 06:57 AM   #1
Default Internal wiring for a bipole surround speaker?
I recently took it upon myself to try to rewire a pair of dipole surround speakers that I own to convert them into bipole speakers. The reason being is that I have them mounted on the back wall and I want to get rid of the null at the center point of each speaker.
I figured that the project would simply involve reversing polarity of the wiring to the driver terminal connections on one face of each speaker to put the drivers on each opposing face back in electrical phase with one another. However, when I opened them up, I discovered that the drivers in one of the speakers were already wired with positive polarity on both faces. This threw me for a loop because I no longer had a consistent point of reference.
The two speakers were wired from the factory like this:
Surround R .................... Surround L
(For the sake of accuracy, because these are rear mounted speakers, the L /R orientation is reversed.)
To put it simply, which of the illustrations below is the correct wiring for a a pair of bipole speakers? And which if any is the correct wiring for dipole?
Option A
Option B
Option C
Option D
Thanks for the help.
- Tim
Old 16th August 2007, 07:04 AM   #2
I did some more research, and while I couldn't find anything official, I found enough posts on different forums that I believe these are the proper wiring schemes for biople and dipole.
Bipole is:
Option A
(All drivers wired with standard polarity. Red to red, black to black.)
Dipole is:
Option C
(The front facing drivers wired with standard polarity, and the rear facing drivers with reverse polarity.)
Advice Needed On Dipole/Bipole Wal Mounted Surround Loudspeaker philiprst Multi-Way 9 7th October 2008 06:51 PM
internal speaker wiring dayking79 Multi-Way 1 2nd September 2008 07:44 PM
Internal speaker wiring type Full Range 2 10th August 2006 06:50 AM
Suggestions for full-range internal speaker wiring? coolkhoa Multi-Way 5 26th January 2004 01:13 AM
DIY speaker internal wiring recs zobsky Multi-Way 10 14th August 2003 06:30 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
