Hi!
Could some body tell me where can I find detailed infos about the attached loudspeaker??? (sorry for the bad quality picture) I am most interested for this "diffusor" panel. Tyimo |
#2 |
Have a look at the following BBC document for the LS5/8 which uses a similar principle:
http://downloads.bbc.co.uk/rd/pubs/reports/1979-22.pdf I cannot remember if it covers the design of the front panel cut-out for the bass unit. |
#3 |
diyAudio Chief Moderator
It widens the midrange dispersion of the 300mm woofer. Its the same principle as with slot tweeters.
#4 |
Hi!
Thanks! About the slots: if the slots opening is smaler than the out coming sound wave, than will be a kind of spatial sound? Tyimo |
#5 |
As alluded to in that article, if you make the slot too narrow you will effectively turn it into the front chamber of a bandpass cabinet. Which is not what you want ......... Also remember to leave enough clearance for the units max excursion. /sreten.
#6 |
Yes.
Thanks. What could be the min. slot for an 6.5" (18cm) driver? 13cm =2600Hz? Tyimo |
#7 |
It can't be accurately decided by wave formulas alone. It takes experimentation and measurements for individual transducers. There are many things to balance. One is the off axis behavior of each 6.5'', since the dispersion is dependable on its cone flex and phase plug or dust cup. Then, the cavity behind the slot interacts with the cone shape and movement. The material and thickness of the slot baffle contributes also. Crossover frequency and slope is essential too. The goal is to get better off axis integration and certain desired dispersion without extra cavity and mechanical resonances coloring the area. In pro speakers that many such tricks are used, much wood is cut and many measurements are taken. Subjective evaluation and trial on error, is the order of the day despite the theory. I would try your 130mm starting point, it sounds logical.
#8 |
Thanks!
I will try it soon. Tyimo |
#9 |
.. maybe this helps to find something more
http://home.wanadoo.nl/dezaire/LS3-5a/LS3-5a_clone.htm Regards Heinrich |
#10 |
Thanks Heinrich!!!
Very good links! Greets: Tyimo |
| DIY loudspeaker vs. factory built loudspeaker | keyser | Multi-Way | 83 | 16th May 2011 12:27 PM |
| Loudspeaker for T-amp | ecodoppler | Multi-Way | 2 | 14th October 2005 11:15 PM |
| Loudspeaker POP - How to Fix- | Aural Dan | Everything Else | 7 | 13th December 2004 09:49 PM |
| Please help with my diy loudspeaker | khorne | Multi-Way | 3 | 8th April 2003 08:38 AM |
| HELP 4 a DIY hi-end loudspeaker | joz | Multi-Way | 6 | 1st February 2003 10:53 PM |
