Hello,
I finally have my 206ES-Rs loaded into the Fostex BLH enclosure. I hooked up my old Marantz 1060 amp to them. When I turned on the amp, I was greeted with an awfully loud pop and crackle from both speakers. When i connected the amp to another pair of speakers, there were no noises made on startup. What could cause my problem, and how can I fix it? Thanks!
tubesdude |
#2 |
Sounds like the problem is with your amp. Now reconnect the ES-Rs and see what happens.
| Tube Amp Startup | DreadPirate | Tubes / Valves | 30 | 14th August 2008 01:56 PM |
| Shouty 206es-r | ConExp | Full Range | 4 | 16th September 2007 11:13 AM |
| BLH for the FE 206ES-R- Project Underway | graykeene | Full Range | 19 | 5th July 2007 04:55 PM |
| 206es-r, Open Baffle style | Pendergast | Full Range | 0 | 6th August 2006 02:04 AM |
| ZV5 Startup Troubles | keenlyside | Pass Labs | 0 | 13th June 2005 06:35 AM |
| Page generated in 0.06374 seconds (66.23% PHP - 33.77% MySQL) with 10 queries |
