Old 8th August 2007, 07:25 AM   #1
Brisso57's Avatar
Lightbulb A line array using HiVi B3S or B3N & Apex Jr tweeters?
I know very little about line arrays, but could a column of HiVi B3S Fr's alongside a column of Apex Jr tweeters constitute a reasonable line array? (A sub would be needed for bass ...)
Check out www.aespeakers.com/pics/mini-line/proto1.jpg to see the tweeters.
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 9th August 2007, 02:22 AM   #2
Danse is offline Danse  Canada
There is a post here you may want to review
My Line Array Project Log
Old 9th August 2007, 06:43 AM   #3
Brisso57's Avatar
I omitted to say in my original post that I had seen that thread. Thanks anyway.
Does anyone have an opinion about the suitability of the HiVi B3N (or B3S) for line arrays?
I know the sensitivity is low ... but watts are cheap.
Doug
Old 9th August 2007, 06:35 PM   #4
gtforme00's Avatar
It seems to me that you could maintain half wavelength spacing with larger diameter drivers than the b3s. This would both improve your low end response and cost less (or similarly) as you have fewer drivers to purchase.
I don't know how low the Apex-Jr tweeter can go. But IIWIYS I would find that out first, then pick my woofer size based on the largest I could get away with to maintain half wavelength spacing.
David
Old 9th August 2007, 10:02 PM   #5
the B3N will have good midrange, but will not have bass. You will need a pair of subs to go with these arrays. I've read alot of negative stuff on using dome for array speakers.
Check the needles as a possible option.
Jim Griffin's Needles
Old 10th August 2007, 01:09 AM   #6
Brisso57's Avatar
Thanks.
Check these: http://www.speakersplus.com.au/produ...roducts_id=126
They have greater HF extension and better sensitivity than the HiVi's.
Just as cheap.
The Fr is low enough to tolerate them without a sub.
Could be a better match for the Apex Jr tweeters.
cheers
Doug
Old 10th August 2007, 08:02 PM   #7
Zarathu is offline Zarathu  United States
see
Zarathu's Line Arrays
and
http://pub48.bravenet.com/photocente...31&album=48032
zarathu
Youth is wasted on the young.
Tweeters for line array? maghen Multi-Way 8 11th December 2008 08:09 PM
Mounting tweeters over the woofer in a line array. GuyPanico Multi-Way 8 28th June 2007 11:10 PM
Tweeters for line array? dublin78 Multi-Way 14 12th May 2007 03:08 AM
FS HUGE Line Array Cabs/W Tweeters Turboegt Swap Meet 9 27th September 2005 02:22 PM
Line Array with silver flute and tn28 hivi's jadenlinkletter Multi-Way 10 16th May 2005 02:12 PM
Page generated in 0.09330 seconds (77.89% PHP - 22.11% MySQL) with 10 queries
