Enclosures for Hartley 24"
Old 11th March 2012, 07:29 AM   #21
Etocynned is offline Etocynned
Hey lets get Planet 10, Scottmoose involved and make one each a pair of Onken and Olsen/Nagoka horrns!
can you imagine?
build a spider frame and mount a fe206en coaxially crossed at 200hz!
You know just to see if it would sound okay!
Altec Lansig computer speaker amp, Paradigm atomss, Altec computer sub, Windows PC source
Old 11th March 2012, 09:19 AM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by cyclecamper View Post
All the Hartleys I ever saw were in open-back baffles of some kind.
A TL
David Ruether - Audio Gear...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th March 2012, 05:21 PM   #23
Ya but Dave you could call it a Honken!
thatt is a large tl you show there, its weird i really had to look for it.
Old 11th March 2012, 07:55 PM   #24
a.wayne is offline a.wayne  United States
Sin Bin
Large sealed is what we used to use them in many moons ago ....
Old 5th June 2012, 01:13 PM   #25
topogon is offline topogon  Australia
Default Hartley TS specs and box sizes
This is a rehash of a post I did on another forum about 18 months ago. A google search should have found it. I tested a Hartley 24" anf found it was suited to BIG boxes or open baffle. it won't work in 20 cu ft - it will have a big bass hump.
I use a pair of these in a long path dipole setup of approx 34" cubed dimensions and get pretty much flat bass down to 32Hz without needing the usual 6dB/octave boost you would normally apply to a bass dipole. I cross over at 110Hz to a stacked Quad/Decca ribbon setup.
HERE'S MY EARLIER POST INCLUDING ALL THE NUMBERS YOU'LL NEED TO MODEL A BOX FOR YOURSELF....
A google search still fails to turn up TS specs on these after all these years. So I finally decided to bite the bullet and do my public service bit and measure one.
Fortunately the heat sink pipe provided a safe and convenient place to stick all the bluetac for the mass measurement phase!
I have read online of an Fs of 13Hz and also 29Hz on various forums...both are wrong. I have also read that the unique magnetic suspension design renders TS measurements impractical or inconsistent. Turns out the speaker has fairly conventional numbers - pretty much what you would expect for a big heavy cone with a smallish motor.
Plugging the numbers into WinISD or similar gives a suggestion of a CLOSED box of 1700L or approx 60 cubic feet. So Hartely's recommendation of 24 cu ft is actually a bit small! I guess that's why lossy cabinets or open baffles are popular...to try to compromise on the size.
Anyway here are the numbers from memory...I can supply the extra decimal places if anyone really wants to know although of course numbers will vary from unit to unit. The unit tested was an original 1970s alnico type, not the modern production.
John Corneille
(Melbourne Australia)
Fs = 20.9Hz
Qts = 0.65
Qes = 0.74
Re = 3.7 ohms
VAS = 1250 litres
Sd calc to 0.22 sq metres
That's all the numbers you will need to checkout just how much artificial bass boost you'll get when using "tiny" 20 cu ft boxes!
Old 16th October 2012, 12:28 AM   #26
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by planet10 View Post
Did you take any build pics of that beast???
Old 16th October 2012, 01:56 AM   #27
frugal-phile(tm)
planet10's Avatar
I've only ever seen the pic on his website.
dave
Enclosures for Hartley 24"Hide this!Advertise here!
24" hartley photos - tomtt Subwoofers 50 9th March 2012 11:52 PM
Hartley 24" - anyone have parameters? rdr Multi-Way 19 17th March 2009 10:32 PM
"Karlsonology" (Karlson enclosures/technique) what's happenin' ? freddi Multi-Way 45 29th January 2008 10:06 PM
Hartley 18" Woofer thetubeguy1954 Subwoofers 27 1st December 2007 10:46 PM
Membrane to limit "unloading" in ported-type enclosures? Datoyminaytah Multi-Way 6 18th August 2004 06:36 PM
