#11 |
I second Howard99's suggestion, 30"x30"x20" box with no back. Line the sides of the box with something absorbative and then sit back and enjoy the sound. I have a set of Hartley 24s, and I've never heard anything like them.
If you want a sealed box of some sort, they are going to be huge (~20 cubic feet each). If that's an option for you, you could give that a try. |
#12 |
Thanks alot for the advice, I will try the seal box method...
From my calculation, I think I will build a box of 40' h x 30' w x 29' d That should give me 24 cuft. is this correct? Thanks alot! |
#13 | |
Did you build the seal box? I am planning to do the same project and I am looking for information. Thank you, Victor |
#14 |
Is bathroom sufficient?
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#15 |
OK
This is an open baffle woofer, like it or not. No reasonable box size will provide equal bass extention. Just the way it is. So why fight it? You only have to deal with the minimum distance requirements from the back wall, and if you build a huge box as has been suggested, you already are placing the baffle front far enough away from the back wall anyway. A 26" width baffle with a 6" wing depth and a 40" baffle height will give you more or less flat bass into the lower 30's at a 6 db per octave roll off below that. No box problems or reflections any greater than what a big box will create. Try 3rd order butterworth around 125 Hz to create a standard low pass and go on to what ever midrange you like. This woofer could work well with a quality 8 inch or larger full range. Your only worries are controlling the full range typical upper frequency rise and establishing the proper pad (if any) to match the woofers efficiency with the full range. A simple pad. And you can take care of the full range rising repsonse (and they ALL have a rising response) with a simple inductor-resistor parallel trap. You have the makings of a great, yet simple full range speaker. Just don't over think the situation. |
#16 |
When they build a 3400 l cabinet at a university lab this can't be that wrong.
Caltech Music Lab Home Page |
#17 |
120 cu ft.! Wonder what the F3 ended up being?
IIRC, the X-max of the Hartley 24" isn't all that much, 2 or 3 MM, or close to that. But with a surface area equal to a couple of 18" woofers, you don't need much, even in an open baffle set up. And if you have a stereo pair you will have enough area to play into the mid twenties with out much if any roll off. Should be pretty efficient too. |
#18 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. Last edited by GM; 4th June 2011 at 03:35 PM. |
#19 | |
Unless you meant that to be in inches, 1 cu ft = 1728 cubic inches 24 cu ft = 41472 cubic inches 40" X 30" X 29" = 34800 minus the space occupied by the driver and enclosure wall thickness and internal brace. So no, that's still wrong, it need to be bigger. |
#20 |
All the Hartleys I ever saw were in open-back baffles of some kind.
Probably the wrong choice for a tapped horn, but it would be nice to capture that back wave in some additive fashion. |
| 24" hartley photos - | tomtt | Subwoofers | 50 | 9th March 2012 10:52 PM |
| Hartley 24" - anyone have parameters? | rdr | Multi-Way | 19 | 17th March 2009 09:32 PM |
| "Karlsonology" (Karlson enclosures/technique) what's happenin' ? | freddi | Multi-Way | 45 | 29th January 2008 09:06 PM |
| Hartley 18" Woofer | thetubeguy1954 | Subwoofers | 27 | 1st December 2007 09:46 PM |
| Membrane to limit "unloading" in ported-type enclosures? | Datoyminaytah | Multi-Way | 6 | 18th August 2004 05:36 PM |
