I'm in the process of building a HT speaker setup using MTM configuration on all five speakers (Vifa PLW11 & PLH270). The first test speaker is done and it sounds great! However for this system I would like to build stereo subs, in a side firing configuration, to the base of 2 of these speakers by extending the height of the box to create a tower. A driver in this configuration will have its magnet between 3.7 and 4.2 cm's from the opposite side wall (internal width is 12 cm) - would this cause problems that could not be resolved by some damping with a dense material like felt or tar sheets? I would use a Vifa PLW22 in 13 liter enclosure (Fc @ 57Hz) and it will be driven by a 200W amp and a Marchand WM8 Bassis EQ (which should hopefully move the response down a further octave or two). Any input welcomed. Thanks, Tim. |
#2 |
Like this.
the config is 1 audax 6.5" driver and a titanium tweeter. and a kenwood 10" driver side fireing ported out the rear. THERE loud too. |
#3 |
: O )
| Mounting speakers side by side | jamikl | Multi-Way | 2 | 6th August 2007 06:01 AM |
| My GC is up and running, side by side with P3A | Jean | Chip Amps | 2 | 21st July 2004 11:38 AM |
| Low side driver as a High side | fr0st | Parts | 0 | 8th May 2004 03:14 PM |
| With GOD on our side! | jag | Music | 0 | 6th March 2003 12:36 AM |
| Page generated in 0.08647 seconds (73.72% PHP - 26.28% MySQL) with 11 queries |
