I am building the Poor Man`s Strad from Troel Gravesen`s site. This is a loose clone of the Sonus Faber Stradivarius and requires building a curved front and rear enclosure. I am using plywood and will kerf cut it to allow the bends. My question is what should i use to fill the cuts as i bend it around the inner braces and ribs? I don`t know whether to use wood filler or some kind of putty. Has anyone done this kind of thing before?
Steve. http://www.troelsgravesen.dk/PMS.htm |
#2 |
The one time I tried this, (not for a speaker, but furniture), I used one of the foaming polyurethane adhesives both to hold the curve and fill the gaps and it worked very well.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Do you mean something like Gorilla glue or the expanding stuff in the can spray foam?
#4 |
Hi castlesteve,
Save yourself some aggravation (maybe anyway) and try looking here for what you need: http://bd-international.com/ http://www.google.com/search?hl=en&q=curved+plywood Good Luck! I hope what you need is already made just waiting for you to take it home! Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner? |
#5 | |
#6 | |
Al's is very good, but can take a while to dry and be kind of messy (run all over the place). I have used silicone before. It dries quick, doesn't shrink and goes where you put it. Skins in about 15 minutes. Oh, it has damping properties also. |
#7 |
Castlesteve, end up making the poor man's strad? Just curious, I just finished up the 2.5 clones and am thinking about doing the PMS.
| DAC cutting out | malcontent | Digital Source | 10 | 2nd March 2007 09:19 AM |
| T-Amp Channel Cutting Out | Diomedian | Class D | 16 | 15th February 2006 11:34 PM |
| Cutting Circles | shanahan | Multi-Way | 11 | 17th June 2004 01:31 PM |
| Cutting MDF | Vivek | Everything Else | 11 | 22nd February 2004 06:30 PM |
| Page generated in 0.09089 seconds (74.84% PHP - 25.16% MySQL) with 11 queries |
