Hi, just got this crazy idea
With a coupled cavity 6th order bandpass sub 20-50hz is possible, driven by its own amp Topsystem consist of 12" and 5" and tweeter, mostly because I have the drivers Well, I know enough to realize that this wont work, on the other hand I am tempted to try
#2 |
You've lost me, that is not a "coupled cavity bandpass" sub. If your actually talking about a double box reflex, I'm not convinced about the methodology for a given total box volume at all, a better driver choice seems more effective, but the DBR seems to allow a very low Qts driver to work in big boxes in a fashion. |
#3 |
It is what you seem to call a DBR .... well, I maybe should have said 4way, and you are right about the big volume, its around 130 liter for the sub alone, and the additional 12" midbass will need another 60 liter minimum, so yes its a big one
what is tempting, at least to me, is the very low cut off(drivers Fs/18hz), and narrow passband with upper limit around 50hz Subdriver has low Qts=0.19 and Fs=18hz ... its a 92db SPL and Xmax may be a little small at around +/- 6mm (?) How much Xmax do think is needed for this DBR sub going down to 20hz ? How is rolloff below 20hz ... will it get "unloaded" ? |
#4 |
Nope its not a DBR. That would only have the 12". So there is a 15" lurking inside the bottom box ? 6th order BP has 2 vents, 4th order BP the 1, the difference being the rear being vented or sealed, the front always being vented. Cannot really see the point for the sub over normal sealed or vented. |
#5 |
Ok, but there is a 12" inside the bottom box with double chambers and two ports ... drivers backside is portet into the front chamber, so it should be 6th order allright, hence the narrow passband
The advantage over normal BR ? ... 18hz with a low Qts driver I reckon that impulse behaviour cant be any worse than normal portet or various TL ... actually I have heard a very cheap 4th order bandpass sub play quite nice |
#6 |
Tinitus,
Go for it! I am using a 6th BP for sub-bass duty high-crossed @80Hz and it's very convenient for me because it's not muddying my subhorns (80-400Hz) which seem to radiate the full bass spectrum (sub-bass included). The low distorsion figure and eficiency of 6th BP aligment is the main advantage, the second been the low off-band energy. But the second advantage must be complemented by good midbass channels. Cheers, Dorin |
#7 | |
Please gives specs of said driver that works better in a 6th order .... You are correct in that a correctly designed BP the low pass section is equivalent to a 2nd order LP filter - fixed frequency - if this is correct it will work well with high power handling before cut-off. |
#8 |
Thanks fore good response, but I now see a minor problem
The 12" midbass in closed box with shallow rolloff slope may result in too much overlap on the sub ... well, I think it may cause problems, not really sure but it might be a bit tricky to get smooth response At the moment I use double 8" in closed and it gives me plenty bass and good lowend too, sounds very nice but I still miss the lowest sub region so I am still very tempted by this Sreten, this would be the "sub" driver ... what I like is the low Fs=18hz with only 100gr. mass, and the low Qts ought to give good controll http://www.monacor.dk/produkter/hoej...12/vnr/101830/ |
#9 |
I think I might have solved the problem with the bandpass sub integration with the midbass overlap
Ofcourse, as I said earlier the sub will need a seperate amps ... with room gain the sub will need some level attenuation, so the drivers might actually blend very nicely |
#10 |
Hmmm..........
shown is said driver with 17.5L sealed, 35L reflex and 90L 6th BP. The BP is incredibly sensitive to port tuning, very large, gets nowhere near 18Hz, and is pretty much an in room boom box in my terms. |
| 2.5 or 3way | deki | Multi-Way | 13 | 18th July 2007 02:33 PM |
| Vifa M18 in 3way? | Mos Fetish | Multi-Way | 42 | 19th August 2006 05:49 AM |
| First Build (3way) | Baronty | Multi-Way | 6 | 14th October 2004 09:20 PM |
| Page generated in 0.10876 seconds (78.68% PHP - 21.32% MySQL) with 11 queries |
