Mounting speakers side by side Mounting speakers side by side - diyAudio
Old 5th August 2007, 07:21 AM   #1
jamikl is offline jamikl  Australia
Default Mounting speakers side by side
In the full range threads, Peak ( Coral ) 8CX 50, I mentioned some backed loaded horns I had many years ago with two of these 8" units mounted side by side. I miss them. My current idea is to get two 8" units locally, at not very high cost, and build similar horns which will only handle frequencies up to about 250 HZ, I would use horns above this frequency also. Perhaps one of the small fostex or other small full range mounted on something similar to an Oris horn. Hopefully this would go up high enough for my now limited hearing.
Would mounting the eight inch units side by side cause any problems in this kind of setup. I loved the shaking bass and speed of the old setup.
I would use the old amp to drive the bass and perhaps build the new Silicon Chip class A to drive the upper horns.
jamikl
Old 5th August 2007, 08:44 AM   #2
tade is offline tade  United States
Send a message via AIM to tade
For frequencies up to 250hz you should be A OK. If you were talking about a pair of full range eight inchers side by side, you might find issues. If you don't trust me, think of this almost like an MTM. Those use two drivers vertically side by side and are often crossed over at 1.5khz and above so 250hz should be fine.
Old 6th August 2007, 05:01 AM   #3
Thanks for the reply
tade. That's the way I saw it but I needed confirmation that it could be done way.
Another interesting thing I found last night was that modeling two silver flute *" speakers, 4 ohms each in series, was that quite a
small rear chamber was need even when using a bass reflex type horn ( as scottmoose is doing ) and the group delay was better than the usual truncated horn that is used in most BLH designs. Efficiency was down a bit from the horn but still quite high anyway.
I think I will continue to work this out as it should be reasonably inexpensive to build. There may be a possiblity of using 4 8" in each enclosure.
Are then any small 4 - 5 inch speakers to cover the mid and highs that might work better in a horn than the small fostex drivers?
At this stage I think I have more chance of a moderately large enclosure which can be used closer to the wall than open baffles which have to be pulled out 4 feet into the room!
jamikl
jamikl
Mounting speakers side by sideHide this!Advertise here!
HT: Side and Rear speakers Brett Multi-Way 45 14th August 2008 10:59 PM
2 bass speakers on the side jimbo Multi-Way 1 4th July 2006 08:41 PM
Low side driver as a High side fr0st Parts 0 8th May 2004 02:14 PM
Side fire sub, how close can magnet be to side? tim_rule Multi-Way 2 2nd February 2003 08:22 PM
Copyright ©1999-2017 diyAudio
