I am refurbishing a crossover that i have a schematic for. On this schematic the DCR for (inductor) L1 is given as .36 ohms. The best replacement i have found is rated at .7 ohms. This is a 2nd order 2 way crossover and L1 is on the woofer side of the network. Will this change in DCR significantly move the crossover frequency or cause other unwanted problems?
#2 |
Speakerholic
What size is the coil and what gauge wire is it?
#3 |
The ones i'm looking at are:
http://www.partsexpress.com/pe/pshow...TOKEN=84747979 http://www.partsexpress.com/pe/pshow...TOKEN=84747979 I like this one but i dont want to wait 3 weeks for it to be in stock: http://www.partsexpress.com/pe/pshow...TOKEN=84747979 the ideal is : 2.0 mH 57 x 9.5 x 10 mm Icore , 0.36 ohm DCR 19 AWG |
#4 |
An inductor with higher DCR will lower the efficiency of the woofer. Going from .36 to .7 ohms will only lower it by about half a db, but it will be over a broad range, so you may notice a shift in tonal balance.
Try zalytron.com, they have an 18 awg Erse Super Q iron core inductor for only $7.41, with a DCR of .217. You have to pay with paypal, and shipping will cost a little more than PE. Zalytron also has the a 14 awg 2.00mh air coil inductor, with a DCR of .306. Price is $14.77 Dan |
#5 |
Thanks Dan.
#6 |
Did it Himself
Not only the efficiency, but the Q of the woofer will change (increase), making it sound just a little different.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 |
What would happen if I replaced an inductor with a lower DCR?
http://zaphaudio.com/audio-speaker17-crossover.gif In Zaph's L18 design I plan to build my own coil for the L0 2.2mH to save a few bucks. It's not that hard really. According to online inductor calculators, I can get and even lower DCR at about 0.18ohm. Will that be detrimental to the design? Should it be the 0.30 ohm exactly as he specified? Peter |
| transformer ratings... pls help | JojoD818 | Solid State | 32 | 23rd July 2010 10:42 AM |
| Subwoofer RMS ratings? | Flyin11 | Car Audio | 8 | 24th February 2008 12:52 PM |
| Switch ratings | thefunkybeat | Parts | 0 | 13th March 2007 09:26 AM |
| Amplifier Ratings.... | mrfeedback | Solid State | 9 | 8th January 2003 10:26 AM |
| Are These Wattage Ratings Right? | CryingDragon | Solid State | 9 | 24th September 2002 06:48 AM |
| Page generated in 0.08135 seconds (76.02% PHP - 23.98% MySQL) with 10 queries |
