So.... Tapering a transmissionline lowers the fundamental resonance frequency a bit - by affecting the way the pressurewave converts from pressure (closed end of line) to velocity (open end of line) - if I'm understanding the principles of this right.
I have a transmissionline that is 170cm long, that has a linear taper from 2:1. The question I would like to ask is this: WHERE on the line is the 1/3 point located? (in reality, concerning acoustic properties...) Do I have to compensate for the taper in any way, or do I just do the maths (170cm / 3 = 57cm)? Or should I integrate with respect to line area and suppose that the 1/3'd point is actually closer to the wide end of the taper? (linear maths then give me that the "area-compensated" 1/3-point is at about (170x0.268) = 46cm down from the closed end?) This seems to me to be the better way - don't ask me why, just a hunch... My guesstimate would be somewhere in between. Again, just a hunch. Or am I overlooking something here? Redoing the baffles will be a lot of work for me, so I would really like to get as close to acoustic target as possible.... Does anyone know how to do this, or does someone have experience with offset drivers in tapered TL's? All help and comments appreciated! /Joakim |
#2 | |
Your hunch is correct up to a point, though it's not as simple as using linear math since we're dealing with pressure waves. Anyway, MJK has done the math for a variety of taper ratios including 2:1 in his Classic Alignment tables: http://www.quarter-wave.com/Theory/Alignment_Tables.pdf GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
It would seem that the 1/3 point is almost exactly 1/3 LENGTHWISE down the line...
Okies, thanks for the link and the info! Greetings from Sweden... / Joakim |
#4 |
You're welcome! Not hardly, if you read the text it tells you that it's at the 3/4 WL, not 1/3, point acoustically. I don't recommend it, but if you really want it at the 1/3 WL point (much more stuffing required), then you'll have to do the wave equation math AFAIK to find it.
| Transmissionline Ipod Docking Station | h@kan | Multi-Way | 19 | 12th November 2009 02:24 AM |
| TransmissionLine speaker ... Sd question ? | nickthevoice | Multi-Way | 4 | 3rd September 2008 11:43 PM |
| TransmissionLine Literature | bredin | Multi-Way | 2 | 28th November 2007 05:14 PM |
| Ceramic/Eton Transmissionline speaker | Jan Deckers | Multi-Way | 7 | 13th August 2004 10:07 PM |
| Cornerloading the terminus of a TransmissionLine | jmiyake | Multi-Way | 5 | 12th March 2003 02:12 PM |
| Page generated in 0.08648 seconds (75.48% PHP - 24.52% MySQL) with 10 queries |
