Old 29th July 2007, 03:59 PM   #1
slhijb is offline slhijb  United States
Default Which, Foil Air Core or Iron Core Inductors
Deciding between a high quality Goertz 1.20 mH air core copper foil 12 AWG inductor, and an Erse Super Q iron core copper 12AWG inductor for a series mid-woofer application. The DCR for the air core is 0.141 and for the iron core about 0.05. The speaker will be supported by an 80 watt / channel OTL tube amp. The iron core inductor is rated for 500 watts, but have reportedly been tested at up to 1000 watts with no core saturation. A general rule seems to be, always go air core and foil if possible. Prices of each are comparable.
Question. Will the air core sound better than the iron core? Which would you choose?
Old 29th July 2007, 09:17 PM   #2
sdclc126's Avatar
Foil inductors are considered a waste of money, period. Solid core inductors are usually recommended for inductances higher than 2-3 mH and in high power applications, usually in bass circuits for 3-way or subwoofer systems. The only thing to consider is DCR and how it will affect the rest of the system.
IMHO in your particular application go with standard air core and save your money. That would be my choice and you won't hear any difference.
Soft Dome
Old 29th July 2007, 10:37 PM   #3
ScottG is offline ScottG  United States
Sorry - but I disagree (to some extent).
1st: Air cores vs. solid cores..
Air cores do not exhibit core hysteresis unlike virtually all core-based inductors. Core hysteresis changes the sound, and usually for the worse. (Note you might be able to avoid this issue with an amorphous core.) Air cores do however have higher resistance for a given inductance (than their core-based alternatives). Higher resistance can alter the sound, particularly when its fairly high (relative to the average for the load - i.e. 10 percent of the nominal load or more). Resistance can of coarse increase from an increase in temp. - and in any given loudspeaker *could* be a moving "target". (note however that a driver's VC is far more likely to be a problem thermally than virtually any moderate gauge *added* inductor.. but not any resistor.) Best "bet" here is to use higher gauge wire ..or a multi-strand wire that equates to a higher gauge wire (if you "fear" skin effect).
2nd: Foil vs. std. wire..
Foil can be wound to resonate (mechanically) *differently* than std. wire. I'd venture that most audible differences (if any) between a similar inductor (gauge, conductor, core - if any), are mechanically induced. Furthermore, I also personally find it increasingly difficult to notice a difference between foil vs. std. wire as driver efficiency decreases and as more components are added to a crossover. (..and no, I have no idea why that is.) Which do I prefer (when I can here the difference)? - The foil version (at least in air core - though likely with a solid core as well).
Bottom line: I'd pick the Goertz inductor at 1.2 mH (..and have done so on many occasions - provided their inductance values have what I need).
perspective is everything
Old 30th July 2007, 12:03 AM   #4
owdi is offline owdi  United States
owdi's Avatar
Search!
Iron vs. air core inductors - distortion?
Dan
Old 30th July 2007, 01:24 AM   #5
Perfect-amente! Thanks a ton, Goertz it is.
Old 30th July 2007, 01:42 AM   #6
Magura is offline Magura  Denmark
Magura's Avatar
This is what keeps the snake oil buisness running
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 30th July 2007, 03:24 AM   #7
owdi's Avatar
Magura
Whenever I research something, and can't find any objective arguments to support it, that is what I conclude.
shlijb - zalytron.com has great prices on 14 awg air core inductors. The 1.20 mH has an RE of .243, and a price of $13.06 per inductor. Only down side is the $50 minimum order, and paying by paypal.
Dan
Old 30th July 2007, 03:43 AM   #8
MJL21193's Avatar
Best bet is to buy both and a cheap standard air core. Do a listening test with all 3.
Even if there isn't a difference, you could probably convince yourself that there is.
The results of the test could be reported back here, and it would justify using the favourite descriptive words such as "transparent" or "strident" or "veiled".
Good luck.
Old 30th July 2007, 10:45 AM   #9
Svante is offline Svante  Sweden
Svante's Avatar
Good luck.
Mmm...
Indeed such a listening test would reveal what the audible differences of those exact three coils would have in that exact application.
However, I suspect that the audible effects, if any, would depend largely on the DC resistance of the coils. This resistance can and should be considered when designing a crossover filter, and if it differs between coils, the one that is mismatched will sound "worse".
In other words, the test will not tell anything about if solid core or air core coils is better.
To make the test say anything about other things than DCR, a small resistor should be added to the coil with the lowest resistance to even out the obvious differences. If there still is an audible difference (in a blind test with prober significance blabla) it can probably be explained by core nonlinearities or whatever mechanical vibrations.
My guess is that the foil and wire coil will come out identical, and that possibly the iron core coil is audibly different. Possibly.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 30th July 2007, 10:00 PM   #10
Originally posted by Svante
Mmm...
Things that make you go mmmm..
Resistance mismatch.. depends on how much for a given application.
I done this with varying wide bandwidth drivers in a different applications. Some were eff., and some were not. In each case though it was always connected for a lowpass character (in series).
The solid core vs. air core test did nothing more than show a preference for the air core (be it foil or std. wire) .. and it wasn't a matter of preferring more resistance. Additionally, the add-a-resistor-to-solid core doesn't work out as expected.. it actually sounds worse with a *common* resistor (as I've found it does when adding any common resistor).
To "stir the pot" some more, I'll add on other item that might be of interest to some:
IF you have a passive design, and
IF you have a low-passed low freq. driver unit that requires large inductors, then
You are likely better off with a good (design and parts) *series* crossover.
Iron vs. air core inductors - distortion? owdi Multi-Way 9 5th August 2007 09:20 PM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 8th May 2007 12:02 AM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 02:28 AM
Erse indictors vs. Copper Foil Air Core Inductors? G Multi-Way 4 5th July 2004 01:45 AM
Air core vs Iron core Ilianh Multi-Way 5 2nd January 2003 02:36 PM
Page generated in 0.14068 seconds (89.20% PHP - 10.80% MySQL) with 11 queries
