#11 |
hi..i have 0,5mh air core inductors..my multimeter is broken and i dont know how much resistance they have..do you have an idea..it has about 3cm radius and 3cm height..thanks
#12 | |
Custom Title
The guess would be about .4 ohms, but is highly dependent upon wire gauge.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#13 |
I agree with most of it
About coil resistance I thought it would only matter on bass Which means it will also matter on a 2way and 2.5way, in some cases even a higher resistance may be preferred Only on a pure midrange it wont matter |
#14 |
http://cgi.ebay.com/Copper-Foil-Air-...rkparms=66%3A2|65%3A15|39%3A1|240%3A1318
its same but i have 0.5 mh inductor..i think its 0.075ohm..its very low isnt it ? |
#15 |
From what I've read, the laminated steel core inductors tend to have the least distortion of the saturable core types.
I generally like the foil types, but the insulating tape dielectric properties become more important than for round wire types. I once did an xover with early Solo inductors using mylar instead of polypropylene tape and replaced them later with Goertz types because of the improved (less harsh) sonic properties of polypropylene. Foil type inductors generally have two advantages over round wire types: less skin effect, meaning the inductance is more constant to higher frequencies (more important for HF applications where skin effect is more noticeable as a coloration in the sound) and they don't 'sing' like most round wire inductors do, due to their very solid mechanical construction. Of course, this can largely be minimized for round wire inductors by potting them, but many of them do not come that way, so I've taken to using 'Hot' CA to basically glue the windings together before installing round wire inductors. |
#16 | |
#17 | |
Dear friend. While trying to upgrade my speaker crossovers.I trashed by mistake a pair of original air coil inductors.
I know how important is DCR on the original crossover network.Here are the values: Mid-range coil: 0.418 mH 0.6 ohms 0.8 mm diameter Tweeter coil: 0.228 mH 0.4 ohms 0.8 mm diameter I know these are the correct values.A friend measure them for me. Could you please help me find the coils to match my speakers.I miss them so much.Your help would be appreciated. I forgot to mention ....that i found a web page that have some coils. Here: Jantzen Inductors - Core Round Wire Let me know what you think. Thanks in advance. Quote:
| Iron vs. air core inductors - distortion? | owdi | Multi-Way | 9 | 5th August 2007 08:20 PM |
| air core inductor vs. iron core inductor | WBS | Planars & Exotics | 5 | 7th May 2007 11:02 PM |
| Solen Air core inductors, Hammond Iron core. | gnomus | Swap Meet | 0 | 30th July 2004 01:28 AM |
| Erse indictors vs. Copper Foil Air Core Inductors? | G | Multi-Way | 4 | 5th July 2004 12:45 AM |
| Air core vs Iron core | Ilianh | Multi-Way | 5 | 2nd January 2003 01:36 PM |
| Page generated in 0.10141 seconds (79.75% PHP - 20.25% MySQL) with 11 queries |
